Nash
posted on 22/10/09 at 06:33 AM |
Brake res labelling
Morning all.
A while ago someone posted a label dealing with IVA requirements for brake resovoirs. You know the yellow label that has to be within 100mm of the
resovoir.
I have unsuccessfully searched for the post so does anyone know where I can find it or is a label commercially available?
Thanks in anticipation.
....... Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
dunk3
posted on 22/10/09 at 06:46 AM |
I went to the scrapyard and got one of a rover 200, i think they are on the 400, and 600, models too.
adrianreeve
posted on 22/10/09 at 07:21 AM |
Car builder solutions do one for a pound.
Adrian
tomgregory2000
posted on 22/10/09 at 07:24 AM |
here you go
click me stick me
turbodisplay
posted on 22/10/09 at 07:28 AM |
I noticed that as well, a simple but very hard to find part.
I have delt with screen printers in order to get a graphic overlay made up.
The cost per unit can be cheap, but tooling can be expensive.
Edit: typing too slow, £1 is very cheap from cbs.
If you know about cars you do not need a sticker, if you don`t a sticker will still be of no use. Especially if you are like my
"friend's" sisters boyfriend- if it isn`t enough oil the oil light will come on!!!!
Darren
[Edited on 22/10/09 by turbodisplay]
paul the 6th
posted on 22/10/09 at 11:20 AM |
ooh, I didn't know about this requirement... Are there many other "stickery" points on the IVA?
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
Nash
posted on 22/10/09 at 06:50 PM |
Section 18. Manufacturer Plate and Vin Chassis plate
Dashboard all switches require to be correctly labelled.
Water Header tank labelled however the yellow screw cap lid is ok for that.
...........Neil
