Author: Subject: Age related plate... could i get one...
Findlay234
posted on 26/11/09 at 05:53 PM Reply With Quote
Pretty much all of my running gear is from the sierra donor of which i still have the V5. Steering column, front uprights, rear axle, rear uprights, brakes all round, a lot of the wiring loom.
The engine and gearbox come from different sources and are both Toyota and both older than the sierra.
With the above type statement would I be able to get an age related plate?
What if i tried to persuade the DVLA that the gearbox was from the sierra as well and that the only different things were the engine and rack, would this be a BIG nono?
Danozeman
posted on 26/11/09 at 06:14 PM Reply With Quote
Register your donor car with the engine number thats in your car. That shoudl make sure you get one.
Dan
Steve G
posted on 26/11/09 at 06:16 PM Reply With Quote
Dont think they generally fall for that one any more but nothing to lose apart from a stamp by trying it!!
speedyxjs
posted on 26/11/09 at 06:21 PM Reply With Quote
I think you need pics of the engine change
bimbleuk
posted on 26/11/09 at 07:28 PM Reply With Quote
My Striker was made up from a J plate Sierra running gear and a Toyota engine. I have a J plate on it so you should be OK but they aren't exactly consistant between offices.
ReMan
posted on 26/11/09 at 08:37 PM Reply With Quote
You dont need the engine /box even
You will get it with the running gear
How do you thinlk the BECists get age rekated?
austin man
posted on 26/11/09 at 09:28 PM Reply With Quote
Isn't it 3 major component so you have the brakes, transmission (diff etc) why arent you using the steering rack ? that would be the 3rd
Findlay234
posted on 26/11/09 at 10:47 PM Reply With Quote
column and all switch gear could be my third i guess.
Im tempted just to say that the gearbox was originally from the sierra as well.
