alistairolsen
posted on 5/1/10 at 12:55 PM |
Seat belt mountings for IVA
If fitting harnesses and seats on sliding rails, are the book style triangular plate mountings at the base of the bulkhead/transmission tunnel
appropriate?
Also, what is required on the bulkhead above your shoulders, I don't like the look of the middle of the top cross member as a mounting point but
there isn't really any other option?
Cheers!
My Build Thread
Mr Whippy
posted on 5/1/10 at 01:05 PM |
tbh I never liked using the back bulkhead, especially at the middle for mounting harnesses as it looked very easy to bend in a crash. I'd always
weld on a roll bar (as a must anyway unless you want a car on your head) and mount the harnesses to that instead.
[Edited on 5/1/10 by Mr Whippy]
blakep82
posted on 5/1/10 at 01:08 PM |
i still can't work out if eye bolts have to be screwed in to a threaded bush, or can they just be welded to the cage?
________________________
alistairolsen
posted on 5/1/10 at 01:11 PM |
I think they can be welded on. If threaded bush is used, it must be through the tube and welded to both faces, or welded along its length to the wide
of the tube (eww) but not welded end on to the tube so the eye bolt sits perpendicular to the tube face.
The roll bar would be far too high unless you fitted an additional crossmember at the correct height.......
My Build Thread
Mr Whippy
posted on 5/1/10 at 01:13 PM |
as far as I'm aware they must be screwed into a welded in threaded bush or have a bolt on the otherside of a 3mm plate
blakep82
posted on 5/1/10 at 01:25 PM |
it says threaded bushes must be welded at both ends, which is fine. but it doesn't say that you MUST use threaded bushes. weird
as for using the roll bar, you're right its too high, but i have got 2 bars making a X, which happens to be the right height
Bumble
posted on 5/1/10 at 05:09 PM |
Here's what I'm doing....they're not finished yet!! Basically they're machined out of solid block, 50mm long tube section
threaded 7/16 UNF - this to get correct top height for mounting harnesses. They will be welded to rear bulkhead and a sandwich plate fitted so that
they are welded on both sides for strength. Currently weigh jst over 1kg (all 4) but as said, they're not complete and are being
lightweighted!!
HTH,
Matt
