Author: Subject: LUKE Harnesses......which type?
Bumble
posted on 20/1/10 at 01:24 PM Reply With Quote
Right then......about to order some harnesses......LUKE 4 point Black (the shorter ones specifically for 7 type cars - WGM4) - good deal from www.motorsportworld.co.uk - £49/pr.
For the rear straps is there any requirement for bolt in type or clip type for IVA?
Thanks,
Matt
indykid
posted on 20/1/10 at 01:26 PM Reply With Quote
avoneer's got luke harnesses in his track mx5.
the adjusters are a real PITA to use because the webbing's so coarse.
i'd say you're better off looking at sabelt, though at £49/pair, it just depends if you want to put up with the hassle.
tom
blakep82
posted on 20/1/10 at 01:30 PM Reply With Quote
couldn't see mention of them being £49 a pair! they're 49 each as far as i can tell.
if prices are a pair, i'll be buying some of their 75mm strap 4 point harnesses right away!
i don't think theres any requirement on bolt or clip in types. there is a list of appoved markings on the iva manual, as long as your harness has one of those (e marking is one of many) then they should be fine
[Edited on 20/1/10 by blakep82]
________________________
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 20/1/10 at 01:32 PM Reply With Quote
Pretty sure those prices are each as it says harness not harnesses
Bumble
posted on 20/1/10 at 01:35 PM Reply With Quote
Sorry guys......my balls up....£49 ea. Same question though......clip or bolt....any issues with IVA?
jacko
posted on 20/1/10 at 07:14 PM Reply With Quote
When i did grass track i used luke harnesses i rolled cars several times and they always held firm
I know have sabelt and there always coming loose
If it was me i would go for LUKE
Jacko
prawnabie
posted on 20/1/10 at 07:19 PM Reply With Quote
I have caterham LUKE ones in mine and have had no problems.
blakep82
posted on 20/1/10 at 10:22 PM Reply With Quote
back to the real question
as i said, check the markings, and make sure whichever ones you go for have at least one of the required markings from IVA.
also, if you get clip in ones (i plan to on my car) then the clip mechanism has a tiny hole where you put a split pin through to lock it shut. make sure you do this for IVA
