Author: Subject: covering under the dash area for iva?
andrew-theasby
posted on 26/2/10 at 01:30 PM Reply With Quote
If the dash board has to be radiused on its bottom edge, how far under does it have to go, and does the area above where your knees are have to be covered in for IVA? Is fabric covering ok or should it be solid? Thanks
midge
posted on 26/2/10 at 02:03 PM Reply With Quote
My dash was radiused 19mm to meet SVA requirements but I was picked up on the location of some relays on the passenger side (a bit too low). I velcroed a piece of carpet tile from the underside of the dashboard to the back of the scuttle.
Worked a treat and easy to take off later.
Regards
Bluemoon
posted on 26/2/10 at 02:21 PM Reply With Quote
I covered mine (SVAed), for aesthetics, more than anything but it stops them poking around at the wiring.. There was an SVA diagram showing the area behind the dash that needs to meet the radius requirement, most of it should be higher than the dash edge and hence exempt.
Dan
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 26/2/10 at 02:23 PM Reply With Quote
I got some chicken wire and moulded a shape that can slip in and out easily. Covered with some thin foam and the same fabric as the dash, looked quite smart for something tempory
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 26/2/10 at 02:25 PM Reply With Quote
Just to add the cover goes from the steering column to right over the passengers legs to the side of the scuttle. if you looked under the dash you couldn't see behind it
twybrow
posted on 26/2/10 at 04:16 PM Reply With Quote
I used some off cuts of a bath panel I had kicking around. I bent nicely with a bit of warming. It covers my wiring and keeps the sphere of doom away from any sharp bits. Its still not fallen off post SVA!
[img][/img]
gdp66
posted on 26/2/10 at 05:15 PM Reply With Quote
fitted some cheap carpet with velcro.
He had a look under carpet, but didn't check for sharp edges.
under dash
[Edited on 26/2/10 by gdp66]
ashg
posted on 26/2/10 at 06:23 PM Reply With Quote
you may not have to do too much. the regs state that anything 150mm above the base of the seat is tested with the 160mm sphere and everything below is tested with the 100mm sphere.
as i noticed on my iva a 16cm sphere is pretty hard to get up there to poke about with. if your electrics are tidy and there are no silly sharp bits up there then you should be ok.
what i will say is if you go down the road of covering it all up do a proper job as if it looks temporary they can now fail you for it as i found out with my heat shrink and rubber gaiters stretched over my suspension.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
andrew-theasby
posted on 26/2/10 at 07:15 PM Reply With Quote
Some nice ideas there, thanks
Ben_Copeland
posted on 26/2/10 at 07:53 PM Reply With Quote
Carpet here... still on there. Cant see it, unless you look under. SVA guy was suitably happy.
Ben
Locost Map on Google Maps
Enter Your Details Here
