Author: Subject: Documentary evidence of engine age?
NS Dev
posted on 30/4/04 at 07:25 PM Reply With Quote
I have been reading up on the legal necessaries for registration/SVA, and I am now worried about what documents are needed for proving the age of my engine?
I bought the engine some years ago from a breaker, and as such have no evidence of it's age. There are age stamps all over the various castings on it (all of which are 1988) but I have no paperwork. I know it is from a 1988 astra gte 16v but I have no paperwork to prove as much!!
Any ideas/similar problems encountered?
[Edited on 30/4/04 by NS Dev]
posted on 30/4/04 at 08:49 PM Reply With Quote
previously it has been sugested to contact the manufacturer, from the engine number they should know the year it was fitted into a car. so should the police, and really the DVLA should know from their own records anyway, so i dont know why they bother asking us for proof.
wicket
posted on 1/5/04 at 04:59 PM Reply With Quote
You need written age details of the engine at SVA, it determines which set of emission figures you need to achieve. I suggest having a look at the SVA manual section 18 pages 3 and 4.
NS Dev
posted on 1/5/04 at 11:54 PM Reply With Quote
where did you get yours Wicket? How on earth do you get age certification for a Ford Crossflow? most of them are a mixture of bits from all sorts of years now!
The age stamps (cast in numbers) of the various parts of my vauxhall engines, both from 1988 astras, are all either 1987 or 1988.
wicket
posted on 2/5/04 at 09:59 AM Reply With Quote
I know from the serial number stamped on the block that my engine was built in June 1980, and the Ford technical dept will give written proof of age for the SVA man.
There is a Ford reference table of year/month codes for the X-flow engines and a quess there are also one's for other engines as well.
Eric
Mark Allanson
posted on 2/5/04 at 07:29 PM Reply With Quote
Haven't SVA inspectors got the same infromation on engine codes that we have? My engine is the original from my donor (engine number is the same as the last 7 digits of the chassis number) and I have the V5 to prove the age of the car - is that enough?
NS Dev
posted on 3/5/04 at 07:32 AM Reply With Quote
cheers Wicket!! I'll have a word with my local Vauxhall dealer for a start, and if no joy there at least they should be able to give me the details of the contact at Vauxhall tech Dept.
wicket
posted on 3/5/04 at 07:56 AM Reply With Quote
Mark
The SVA engineers may well have the info but the manual specifically says that the onus is on the presenter for proof of age.
Mark Allanson
posted on 3/5/04 at 09:11 AM Reply With Quote
...........but would a V5 with the right numbers be sufficient proof?
barrie sharp
posted on 3/5/04 at 10:19 AM Reply With Quote
Hi mark i will ask on friday at exeter for you
I sent a letter to ford last thurs and got a reply on sat. like you i have the v5 but wanted to be on the safe side!!
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
pointy
posted on 3/5/04 at 03:48 PM Reply With Quote
Barrie
I too have a crossflow engine, although sadly no V5, I bought a big pile of bits from a bloke who "started but didn't finish" a locost.
Could you post the Ford address you wrote to for confirmation of the age of engine so I can do the same.
Also if I get this evidence would I be entitled to an age related number plate or would it still be a Q plate as most of the other components are either new of from a Cortina (not the escort the engine came from).
Many Thanks
NS Dev
posted on 3/5/04 at 05:06 PM Reply With Quote
You are in much the same state as me except I didn't even get the part finished project (though I am buying ST bodywork and chassis and IRS)
I have the Vauxhall XE engine but no logbook. Anybody got the address to write to at Vauxhall too?
wicket
posted on 3/5/04 at 09:44 PM Reply With Quote
Quote from the SVA manual
a copy of the donor vehicle
registration document (where the
engine was the original fitted to
the vehicle).
Ford Technical Information Dept.
PO Box 300
Walsall
WS5 4QH
Tel: 01922 725 551
Fax: 01922 725 266
[Edited on 3/5/04 by wicket]
barrie sharp
posted on 4/5/04 at 07:31 AM Reply With Quote
Pointy my understanding is you must have at least 3 main components from a donor car to get a age related plate.
and when the dlva man comes to see your chassis no he will confirm this.
Thats what happened to me anyway.
SVA two days to go!!!!!!!!
