Author: Subject: IVA And engine MAX RPM/REVS?
Krismc
posted on 11/3/10 at 06:14 PM Reply With Quote
Just filling in my paper work to send to MNR for the IVa and unsure of What too put on the iva sheet for max RPM / Revs?
My engine is a 2.0 litre zetec 1999 130BHP standard.
But has lightened flywheel, TBs, Cams, and around 180-190Bhp?
What do i put?? cheers in advance
tomprescott
posted on 11/3/10 at 06:24 PM Reply With Quote
As far as I'm aware they use the max bhp rpm when doing the emissions testing, they test at the output that you specify so there is the potential to get through the emissions easier by saying 2.5/3k rather than 5.5/6k! Just what I've heard though!
RickRick
posted on 11/3/10 at 06:26 PM Reply With Quote
my forms were sent back for an optamistic rev range so if you get it wrong don't get it really wrong
matt_claydon
posted on 11/3/10 at 07:05 PM Reply With Quote
Noise, not emissions, is done relative to max power speed.
Put the correct figure or an educated guess, they aren't stupid.
jacko
posted on 11/3/10 at 07:34 PM Reply With Quote
Put what it says in the car [ zetec ] hand book ie mondeo
ashg
posted on 11/3/10 at 08:31 PM Reply With Quote
you just put down what rpm the engine is doing when its making max power (not max rpm) just look up the figs for that engine and you will be fine.
noise is measured at 3/4 of what ever rpm you write down. if they dont believe the figure you put they make you do it at 2/3 of your max rpm.
i didnt have the info for my pinto as i tinkered with it so took the printout from my rolling road setup which was acceptable.
[Edited on 11/3/10 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Krismc
posted on 11/3/10 at 08:57 PM Reply With Quote
So what do i actually put?? actuall figures does anyone know??
Krismc
posted on 13/3/10 at 03:19 PM Reply With Quote
so i should say 130bhp and 6500rpm??
40inches
posted on 13/3/10 at 03:33 PM Reply With Quote
iank
posted on 13/3/10 at 05:54 PM Reply With Quote
Haynes say 130bhp (96kW) @ 6000rpm (2.0 litre Mondeo)
[Edited on 13/3/10 by iank]
Anonymous
