Author: Subject: Failed IVA
jack_t
posted on 13/3/10 at 08:58 PM Reply With Quote
Failed IVA
took my mk to nottingham for IVA yesterday and unfortnatly failed on a couple of things
Side repeaters mounted on the scuttle will not pass
- the best place for them is the rear arch but make sure they are less than 2.6 metres from the front of the car and 350mm above the ground
Speedo - i have a koso guage in mine and it worked fine but now its decided it doesn't want to give me a speed over 40mph ( faulty speed sensor apparently)
but flew through emissions without any fiddling ( shell V power helped )
noise was 94db at 7500rpm
will give a full report once ive had it retested
Simon
posted on 13/3/10 at 09:36 PM Reply With Quote
Why won't repeaters on the scuttle pass IVA, when mine passed SVA in that very location?
Good result from the sound of it though
Simon
big_wasa
posted on 13/3/10 at 09:51 PM Reply With Quote
More hoops to jump through.
Wont be long before your on the road
AdrianH
posted on 13/3/10 at 09:53 PM Reply With Quote
The exception they allowed for seven style cars went on IVA. The rear wings block the view of the side repeaters from the back.
Some one was trying side repeaters on the front headlights. I did them on edge of the rear wing.
Adrian
Why do I have to make the tools to finish the job? More time then money.
jack_t
posted on 13/3/10 at 10:01 PM Reply With Quote
wouldn't have worked for me being high up on my scuttle as my aero screan and roll cage would block the view
like i said the best place for them is the edge of the rear arch as the side repeaters are actually needed to be fully operational,
bj928
posted on 13/3/10 at 11:22 PM Reply With Quote
my seem a silly idea, but if a 7style car has problems with side repeaters, can more then 1 be fitted, i was thinking 1 in each arch, and maybe 1 in scuttle or side mirror, as well as normal front and rear, or are we only allowed to fit 1 front, 1 middle and 1 rear
gdp66
posted on 13/3/10 at 11:31 PM Reply With Quote
failed my iva on this.
moved them to rear edge of front wheel arch
www.tigeravon.co.uk
mangogrooveworkshop
posted on 14/3/10 at 12:03 AM Reply With Quote
Sounds like you will end up with a car shaped xmas tree with all those side repeaters
rayward
posted on 14/3/10 at 12:17 AM Reply With Quote
what about repeaters mounted on the underside of the wing mirrors (showing forwards and rearwards)??
surely they will be visible from pretty much everywhere?
matt_claydon
posted on 14/3/10 at 09:42 AM Reply With Quote
Originally posted by ashg
you must have 2 front indicators, 2 side and 2 rear indicators
but you can also have 2 additional side marker lamps towards the rear between the side and rear indicators and 2 side marker lamps towards the front between the front and side indicators, to compensate for your required lights not achieving all the viewing angles.
its all there in black and white in the iva manual.
Note though, side marker lamps are not indicators. They just come on and off with the position lamps.
posted on 14/3/10 at 09:52 AM Reply With Quote
What about mirrors with side repeaters?
I know this was a moot point but new golfs and other oems use them so they must be legal??
speedyxjs
posted on 14/3/10 at 11:33 AM Reply With Quote
Not too bad a fail. Good luck with the retest
NigeEss
posted on 14/3/10 at 01:23 PM Reply With Quote
Thinking the same myself. If it's acceptable for production cars then I can't see why not.
jack_t
posted on 14/3/10 at 03:55 PM Reply With Quote
the indicators on golf wing mirrors would not pass an iva and no indicators on the bottom on the wind mirrors would not work
MR IVA tester says
" have to be mounted within 2600mm from front of car and between 350mm and 1500mm from the ground of which they have to be visible from 15 degrees above the light and 5 degrees below
and 5degrees out and 60 degrees out horizontally
boggle
posted on 15/3/10 at 10:27 AM Reply With Quote
may sound silly, but cant you put them on the edge of the roll hoop????
u2u me for details
jack_t
posted on 15/3/10 at 11:50 AM Reply With Quote
i dont see a problem with that aslong as they are above the reach arches
