Author: Subject: how to make this IVA proof???
rayward
posted on 21/3/10 at 06:55 PM Reply With Quote
got s problem with a stuck out weber, any (Sensible) ideas on how to make this pass the exterior projection checks ??
cheers
Ray
dunk3
posted on 21/3/10 at 07:00 PM Reply With Quote
hi ray, can you put some wire mesh over it. so its like a cage.
[Edited on 21/3/10 by dunk3]
tegwin
posted on 21/3/10 at 07:06 PM Reply With Quote
The outside of the filter should pass...
You need to replace the wingnuts with flush dome heads though.... then just cable tie a piece of rubber over the top of the carb body to cover up the bolt heads on top...
www.verticalhorizonsmedia.tv
ashg
posted on 21/3/10 at 08:01 PM Reply With Quote
bits of rubber cable tied on are no longer acceptable. its in black and white in the manual.
chicken wire bonded on to the back of the bonnet or find a lower profile filter if such a thing exists.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 21/3/10 at 08:36 PM Reply With Quote
I would suggest getting a fibreglass kit and making a custom scoop? Would be a good skill to learn too
