Author: Subject: Its MOT time again
jacko
posted on 3/4/10 at 07:32 PM Reply With Quote
Its MOT time again
At my last MOT the tester wanted proof of the weight for doing the brakes on the rollers
After a chat with him he did it at 650kilo
im hoping he will do it this year
Has any one else had this problem at MOT time?
RichardK
posted on 3/4/10 at 07:36 PM Reply With Quote
Isn't it your v5? I know it was deffo on the sva paper work but maybe you didn't keep a copy.
Don't you know anywhere with a weigh bridge would be another thought. Trading Standards offices have them sometimes.
Rich
Gallery updated 11/01/2011
jacko
posted on 3/4/10 at 07:41 PM Reply With Quote
I will have a look on the v5 I did have a copy of the sva paper but cant find it
scudderfish
posted on 3/4/10 at 07:49 PM Reply With Quote
If they don't have a registered weight, they should do it with a calibrated accelerometer. Also needed for full time 4wd vehicles.
My Fury has been done twice like this, the first time the MOT guy didn't buckle up and I nearly put his head in the dash
scudderfish
posted on 3/4/10 at 07:53 PM Reply With Quote
Have a look here
http://www.motinfo.gov.uk/htdocs/m3s03000001.htm
Xtreme Kermit
posted on 3/4/10 at 08:06 PM Reply With Quote
Mine has always been done using an accelerometer as to use the rollers correctly, I thought you needed to know the split between front and rear.
They wouldn't put mine on the rollers this year becasue of the limited slip diff - although I cannot figure out why that would make a difference...
scudderfish
posted on 3/4/10 at 08:11 PM Reply With Quote
Because they test the wheels individually. If you have an LSD you can spin them independently.
jacko
posted on 3/4/10 at 08:16 PM Reply With Quote
Mine has a LSD
stevebubs
posted on 3/4/10 at 08:20 PM Reply With Quote
Go down the local tip and stick it on the weighbridge...
RichardK
posted on 3/4/10 at 08:38 PM Reply With Quote
blakep82
posted on 4/4/10 at 01:32 AM Reply With Quote
was gonna say that, the council have them for their lorries
________________________
Mark G
posted on 4/4/10 at 07:54 AM Reply With Quote
You don't need to tell the tester what the weight of the car is. That's not your job, it's his.
