Author: Subject: Failed in Exeter
barrie sharp
posted on 11/5/04 at 10:03 AM Reply With Quote
Failed in Exeter
Failed the sva
but was quite happy with why on some things !
Steering wheel :sva man said leave the serria one on. in the test said it was too big and could hinder proper control of the car!!!
Exhaust : lolocost one front edge of the box edges not greater than 2.5mm (just)
Mirrors: too small my fault for reading the rules wrong 40x80 should read 40x80 with a 70mm in the middle somewhere.
Self centreing :total lack of.. toed out loads (looked silly)still nothing.
Lights: needed ajusting and centreing.
Brake warning light : no reconised symbol on lamp.
One battery cable not tied for 300 mm and fuel filter not fixed down
And some sharp edges on the top and bottom of the shocks at the front.
Not much really done most of it just got to phone for retest and pay £30 cash!!!
Apart from that he said it looked good
[Edited on 11/5/04 by barrie sharp]
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
Deckman001
posted on 11/5/04 at 10:11 AM Reply With Quote
Bad luck with the fail, not sure what you can do/say about the steering wheel item, can't understand why everybody else passes with it but not you , maybe a question for people higher up in the VRO ?
Jason
barrie sharp
posted on 11/5/04 at 10:16 AM Reply With Quote
Hi jason
he said i know your going to change it but it just touched his knees and said he could not pass it due to a dispute with a kit car manifacturer and some pictures??
Mk-Ninja
posted on 11/5/04 at 10:53 AM Reply With Quote
Bad luck. But at least there is nothing terminal, and you have a list to work through. All the best for the retest.
Gordon
I'm sure I've got one, just don't know where I've put it
timf
posted on 11/5/04 at 10:54 AM Reply With Quote
Originally posted by barrie sharp
Hi jason
so what has that to do with you, you may fit under the wheel no problem.
Deckman001
posted on 11/5/04 at 02:37 PM Reply With Quote
Not sure this is poss, , but can you raise the column where it mounts on the chassis?
Jason
barrie sharp
posted on 11/5/04 at 03:09 PM Reply With Quote
Thanks jason i have already lifted the coloum up by an inch and fitted a fiesta sports steering wheel also an inch smaller should be enough.
But then again who knows!!!!
Mr G
posted on 11/5/04 at 03:11 PM Reply With Quote
Bad luck but does'nt seem much to do to get it sorted , me and Billy were only in there yesterday talking to the kit tester about various sva bits and bobs (seemed like a nice enough bloke)
G
Deckman001
posted on 11/5/04 at 06:40 PM Reply With Quote
Don't forget to recheck the radius around the new smaller wheel, 127 mm rings a bell, just a thought seeing as you've reduced the size of steering wheel and buttons and switches might now be outside the safe zone
Jason
barrie sharp
posted on 12/5/04 at 10:27 AM Reply With Quote
Retest Fri morn 14th 8.00 lets hope it all goes ok .
anyone know if softer or harder pressures in tyres make the self centreing better or worse .I am running 20psi at the moment and i get a bit of self centreing but unable to drive too much due to pc plod living 5 doors down
tfyt Barrie
spunky
posted on 12/5/04 at 10:58 AM Reply With Quote
Hi Barrie.
lowering the tyre pressure aids self centering, about 16psi.
Good luck with the retest.
John
Deckman001
No idea about the centering, but good luck on Friday anyway
Jason
NS Dev
posted on 12/5/04 at 04:37 PM Reply With Quote
mentioned this before and probably won't be able to, but if there are any spacers (washers?) either side of your upper and lower wishbone bushes to fit them between the brackets then make sure that the washers on the top wishbones are in front of the bushes and those on the bottom are behind the bushes. (to maximise castor angle) Also check the wishbones are the right way up (silly but best to check!)
billy
posted on 12/5/04 at 09:27 PM Reply With Quote
re- test
hope it goes well barrie, oh and you must drive it round to see me if you pass id like to take a look, ill show yah mine too.....lol
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
Bob da builder
posted on 13/5/04 at 08:12 AM Reply With Quote
Barrie,
hard luck mate, but at least you will pass the next time!
if it makes you feel any better my SVA is on the 20th may (1 week!!) and i dont even have an engine, itz knackered!!!
the low level brake light: do you have to have a symbol on the light?? i dont but at the end of the day i know what it is!?!
all the best for the 14th!
bob
barrie sharp
posted on 13/5/04 at 08:46 AM Reply With Quote
Bob
is that the lights on the rear of the car
if so all they checked on mine were that they were working.
if its the one on the dashboard yes you need the symbol.
good luck for yours.
Barrie
ps just put pictures on the archive first time since i been on this site!!
Bob da builder
posted on 13/5/04 at 03:34 PM Reply With Quote
barrie,
the cars looking very nice!! its a little scarey how similar it looks to mine, same style wheels, same dials, colour, engine ets and weve never met!!!
yep itz the symbol on the dash light that i dont have, doesnt mention it in my SVA manual (i think!) but then again i have had it for 3yrs!!!
again good luck for the retest, keep us posted!!
barrie sharp
posted on 13/5/04 at 09:24 PM Reply With Quote
It s the symbol that was one of my fail points its not in the book BUT IT IS IN A SUPPLEMENT ON THE SVA MANS DESK.
yes i missed that one as well they get supplements all the time and like showing you when you point it out that its not in the book!!
All i did was draw the symbol out quite big photocopy it down small and varnish it to my light .looks good lets hope mr sva thinks so
Bob looked up your car and they are simalar but are your rear belt bolts high enough (dont want to scare you but mr sva got this funny tool out and i was only 1/2" over .)
thanks i,ll let you know how i get on tomorrow
Bob da builder
posted on 14/5/04 at 07:34 AM Reply With Quote
barrie,
dont worry you havent scared me..... well ive measured it based on 450mm from the referance point so unless the 450mm has been increased in those dam suppliments then i reckon i should be fine....fingers crossed!! the seats you see in the photo are only SVA tempoary and are only 3/4in thick, i have made fibre glass seats moulded to me, you could say they fit like a glove!! but are borderline for the SVA and i havent got them covered yet either!
but if you spot anything elso please shout!!
as for your light symbol, what you had done is simmilar to my idea but was goining to cut it out of vinyl left over from my silver stripes! either way so long as it passes!!!!! if it does (as im sure it will!!) your going to have a dam good weekend!!!!
take it easy mate
bob
