Author: Subject: are these legal?
A1
posted on 27/4/10 at 02:11 PM Reply With Quote
are these legal?
http://www.cbsonline.co.uk/led-running-lights--100mm-x-30mm-ledrun-4754-p.asp
just the other ones are a bit much...will these pass iva?
cheers
jossey
posted on 27/4/10 at 03:00 PM Reply With Quote
no chance :O)
David Johnson
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 27/4/10 at 03:09 PM Reply With Quote
If you want daytime running lights just fit them after IVA
A1
posted on 27/4/10 at 03:21 PM Reply With Quote
IVA says you need them though....
russbost
posted on 27/4/10 at 03:24 PM Reply With Quote
No it doesn't - common misconception!
iank
posted on 27/4/10 at 03:27 PM Reply With Quote
No it doesn't, they are optional (at the moment). Look at the table on page 5/6 of the "22 End-outline, Position (Side), Stop, Side Marker & Daytime Running Lamps" section.
Anonymous
