Author: Subject: fuel pipe in passenger compartment
gavin174
posted on 23/5/10 at 07:07 PM Reply With Quote
Gave the car a bit of a pre IVA thrash about today..
when i checked everything over afterward i found the gearbox has moved more than i thought it would.
It has put a dent in copper fuel pipe in tunnel.
I obviously want to change it before IVA,can i run copper or braided fuel hose on the outside of tunnel in the passenger compartment..
RichardK
posted on 23/5/10 at 07:11 PM Reply With Quote
What about a stiffer gearbox mount? Shouldn't move too much or is the pipe pretty close?
Wouldn't want a fuel line in the passenger side as I don't think it would just look right.
Rich
Gallery updated 11/01/2011
Stuart_B
posted on 23/5/10 at 07:19 PM Reply With Quote
as said, i would go for a stiffer mount, or re route the fuel pipe down the tunnel still but out off the way, or in rubber or braided for a section?
stuart
wilkingj
posted on 23/5/10 at 08:01 PM Reply With Quote
I would NOT put any fuel pipe in the cab / passenger area.
In the event of a fire, you want this as far away from people as possible.
Check the IVA rules, as I am sure there was something in the SVA manual about it.
Certainly you cannot run fuel and electric alongside each other. (A bit obvious really)
I have my fuel and electrics on opposite sides of the tunnel and inside the tunnel.
Best Regards
Geoff
http://www.v8viento.co.uk
gavin174
posted on 23/5/10 at 08:03 PM Reply With Quote
I have messed up.. I ran the brake lines fuel lines and electrics before i put the engine and box in..
the rear of the box was close to the fuel pipe, but i thought i would be ok.
the main problem is I made my tunnel top out of steel and rivetted in and fillered the edges..
I will probably have to bite the bullet and take it all off.....
blakep82
posted on 23/5/10 at 09:16 PM Reply With Quote
like an electric fuel pump, or fuel gauge?
the only thing i've ever found in the manual is that it must not leak, and must be securely attached to the car
________________________
RIE
posted on 24/5/10 at 07:48 AM Reply With Quote
"The fuel tank must be positioned so that in the event of a leak the fuel could not accumulate or find a path to the passenger compartment."
The manual says that about the tank, doesn't mention anything specific about pipes.
