Author: Subject: Racetech mirror will it pass Iva ?
big_wasa
posted on 7/7/10 at 08:02 PM Reply With Quote
Ive got a Racetech Interior mirror It meets the size req' and can be moved from side to side but not up or down.
I can see as much out of it as I will with any other, looking through the stays of the roll bar.
So any one passed or failed with one.
cheers
[Edited on 7/7/10 by big_wasa]
Stott
posted on 7/7/10 at 08:28 PM Reply With Quote
yep, mate had a fail for one last month, sharp edges on the bit you look at surrounding the glass, trim stuck around it passed that off in the end, he originally had smoothed it all off but that wasn't sufficient as there was still a contactable edge, due to the glass being slightly recessed. The thickness of the plastic not being enough to put a r2.5 on it
HTH
Stott
dan__wright
failed on sva due to radius at leighton buzzard, field of view was fine if its the same as sva
FREE THE ROADSTER ONE…!!
FrankP
Hi - as long as the exteror mirrors are BOTH Ok then you dont actually need an internal mirror as I understand it.
Frank
Stott
posted on 7/7/10 at 08:35 PM Reply With Quote
^^ No you need the offside and an interior, they make the 2 req'd (this was the previous fail point - lol)
You can only get off without an interior mirror if it offers absolutely no rearward vision, as in a panelled van, looking back through a full cage and a GSXR1000 airbox are fine, apparently, so you need one hahahaha
[Edited on 7/7/10 by Stott]
big_wasa
posted on 7/7/10 at 08:51 PM Reply With Quote
Thanks.....
ashg
posted on 7/7/10 at 09:58 PM Reply With Quote
i passed with one on mine. had to put rubber trim round the edge and heat shrink round the bolt bit on the base
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
