franky
posted on 10/8/10 at 08:12 PM |
can you run fuel pipes together?
As above, are there any rules about fuel pipes(copper nickel type0 touching(feed and return) running from the tank to the fuel rails?
snapper
posted on 10/8/10 at 08:15 PM |
Nope just need P clipping properly
I eat to survive
I drink to forget
franky
posted on 10/8/10 at 08:17 PM |
Cheers for that, i'm actually using cable tie bases that i've riveted to the chassis.... I know cars have passed IVA with them.
gavin174
posted on 11/8/10 at 05:19 AM |
not a good idea to have them touching thou
vibration will eventually rub through them.
franky
posted on 11/8/10 at 09:52 AM |
I was going to use some thin sticky back foam between them to stop any vibration rubbing.
Bluemoon
posted on 11/8/10 at 10:36 AM |
I would run them separate, and use rubber linings on P clips (i.e cut down rubber hose, or rubber lined P clips).... Mine has the return and feed with
two separate rubber lined P clips on the same rivet the pipes are thus physically separate and soft mounted.. Not sure I would want to mount with
cable ties in direct contact with the Cu pipe..
