Author: Subject: Cockpit sides
Macbeast
posted on 18/8/10 at 07:03 AM Reply With Quote
Cockpit sides
I suppose for IVA I should put some girly padding on the top struts either side of the cockpit ( where the elbows go )
What do people use ? Can I buy U-shaped foam an inch and a fraction wide ?
matt_claydon
posted on 18/8/10 at 07:05 AM Reply With Quote
Why? all you need is 2.5mm radius on the edges, not padding.
Most people use something from a coachbuilding supplier like the stuff on this page: http://www.hartwood-elite.co.uk/c/horsebox-aluminium-mouldings.html
[Edited on 18/8/10 by matt_claydon]
Macbeast
posted on 18/8/10 at 07:10 AM Reply With Quote
I suspect that the top strut edges with the glassfibre turnover would be less than 2.5 mm rad.
Thanks for that. I suppose the edges have to be blunted both inside and out ?
Which is why I was thinking of U-shape rubber
[Edited on 18/8/10 by Macbeast]
Flamez
posted on 18/8/10 at 07:11 AM Reply With Quote
Look for "hockey stick" moulding.
my build mac1motorsports
macc man
posted on 18/8/10 at 04:05 PM Reply With Quote
I used foam section from a new worktop used to protect in transit. Nice and firm and protects arms from bruises.Coverd it with vinyl and glued down looks good.
Macbeast
posted on 20/8/10 at 06:56 AM Reply With Quote
Thanks for suggestions
