posted on 28/8/10 at 04:50 PM |
Dash... MOT Requirements?
What instruments and tell-tale lights does the dash NEED to pass an MOT?
Ta!
It's Evolution Baby!
posted on 28/8/10 at 07:02 PM |
Speedometer, main beam, indicators and brake fluid tell tale.
omega 24 v6
posted on 28/8/10 at 07:16 PM |
and fog light
bigrich
posted on 28/8/10 at 07:31 PM |
foglamp telltale, indicator/hazzard telltale, abs lamp if abs fitted.
posted on 28/8/10 at 08:05 PM |
Cheers... so just to re-cap so I get this right, the only instrument needed is a Speedo, and the only Tell-Tale's are:
Main-Beam
Indicators
Hazard
Fog
Brake-Fluid
loggyboy
posted on 28/8/10 at 08:16 PM |
I dont recal seeing speedo being in MoT manual.
http://www.motuk.com/mot_manual/index.asp
Will be against construction and use regs I would imagine.
[Edited on 28/8/10 by loggyboy]
bigrich
posted on 28/8/10 at 08:41 PM |
speedo is not tested on the MOT, main beam warning is an advisory item and I believe a brake fluid level warning lamp is only required if the fluid
resevior is not transparent and marked with a minimum level.
