Author: Subject: donor plate
chesney321
posted on 11/9/10 at 07:21 AM Reply With Quote
donor plate
i am building an aries locoblade and would like to know if i could register it on an age related plate from the donor bike or will it have to be put on a q plate.also if it does have to be a q plate is it possible to change it at a later date to a private non age related plate.all replies greatfully welcomed
pekwah1
posted on 11/9/10 at 07:23 AM Reply With Quote
not sure about the age related, you need a certain amount of donor parts from the vehicle to warrant that.
As for Q plate, once a Q, always a Q. So if it ends up on a Q plate, you can't have a personalised plate, and you can't even buy different Q plates either
austin man
posted on 11/9/10 at 09:14 AM Reply With Quote
Nope, you would not have enough parts, the age related plate is usually generated from the donor car wher the steering transmission and brakes will be taken from, I believe its base upon 3 major components unless IVA has changed this
big-vee-twin
posted on 11/9/10 at 10:06 AM Reply With Quote
The following values will be allocated to the major components used:
* chassis or body shell (body and chassis as one unit - monocoque ie direct replacement from the manufacturer) (original or new) = 5 points
* suspension = 2 points
* axles = 2 points
* transmission = 2 points
* steering assembly = 2 points
* engine = 1 point
See this link linky
http://www.triangleltd.com
matt_claydon
posted on 11/9/10 at 10:34 AM Reply With Quote
* axles = 2 points
* engine = 1 point
See this link linky
The points system is NOT for kit cars. This seems to be the longest running and biggest misunderstanding in the kitcar world (it doesn't help that the DVLA often get it wrong too!) The points system allows you to keep the actual original registration and avoid IVA if you get sufficient points, but required an original or identical new chassis.
What we do are called 'kit conversions' and are detailed here:
http://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/RegisteringAVehicle/DG_10014246
If a new monocoque bodyshell or chassis from a specialist kit manufacturer is used (or an altered chassis or bodyshell from an existing vehicle) together with two major components from a donor vehicle, an age related mark will be assigned. The mark will be based on the age of the donor vehicle. An IVA, ESVA, SVA or MSVA test will be required to register the vehicle.
[Edited on 11/9/10 by matt_claydon]
chesney321
posted on 11/9/10 at 12:04 PM Reply With Quote
plate
so if i use the engine and gearbox from a honda fireblade motorbike and put it in my locoblade would that class as the 2 bits needed,and would i then be able to have an age related plate
