ahunt
posted on 8/11/10 at 04:44 PM |
IVA photographs?
In terms of IVA photographing, can anyone tell me what is needed? Is it just the parts that are welded up and then covered by panels like seatbelt and
seat mountings to the chassi? Orrrr does it just have to be as many photos as possible of everything constructed?
Adam
Car 90% complete!!!
panichat
posted on 8/11/10 at 05:01 PM |
I did a sequenced set of about 50 photos showing the car taking shape. I made sure to include photos of the seat belt mounts and plates welded under
the roll bar supports. I included this in the pile of stuff was sent off to VOSA with the application. I took a copy to the DVLA appointment but they
didn't ask to see it.
Better to have it than get caught out I suppose.
Dave
interestedparty
posted on 8/11/10 at 05:16 PM |
It's all about having evidence that it is an amateur build, and it is something they are very hot on. So plenty of pictures in a domestic
background are required, typical single garage, kids sitting in it, ideal stuff
Other than that, any dubious areas that are going to be closed up should have plenty of clear pictures, otherwise you might have to open it up so the
guy can look for himslef. My plan is to have opening panels just in case.
RichN
posted on 8/11/10 at 07:22 PM |
I didn't need any photos for IVA at Nottingham, only as proof of amateur build when submitting the forms for IVA and DVLA.
I was asked to remove one panel above the pedals so that he could view the brake pedal and clevis pin. He tried to look into the tunnel when it was up
on the ramp to see where brake pipes etc.. were routed and secured but didn't ask me to remove the tunnel top.
martyn_16v
posted on 8/11/10 at 08:25 PM |
I sent half a dozen or so along with my IVA application, but at the test itself wasn't asked for any at all. I imagine it's another of
those things that varies depending of which test centre/tester you go to, most are probably going to be fairly relaxed about the whole thing, but you
may be unlucky and end up with the anal retentive on a bad day.
Michael
posted on 8/11/10 at 09:28 PM |
I took a ruck sack full of pictures, was not even ask to show any.
Most on my car was visable including the bottom outer sea belt mounts.
Only took boot cover off as he wanted to see tank breather and boot area that he could not see from underside.
Bluemoon
posted on 8/11/10 at 09:32 PM |
IVA test or application?
