marcjagman
posted on 25/11/10 at 02:29 PM |
Headlight mounting
I am using a home built Locost chassis and wondering what to use to mount my headlights on, what have you guys used? Is there something on the market
that I can buy?
daniel mason
posted on 25/11/10 at 03:18 PM |
Mnr do a mounting bar which bolts across the chassis into top chassis rail. It has a round hole on each end also for bolting lights to! You can get
them powdercoated any colour
marcjagman
posted on 25/11/10 at 04:08 PM |
Had a look on thier site and couldn't see one, what section does it come under?
daniel mason
posted on 25/11/10 at 04:58 PM |
it comes with the chassis as part of the kit but chris a great bloke and would do anything to help. im sure if you ask him he will have one made up
for you!
[Edited on 25/11/10 by daniel mason]
stevegough
posted on 27/11/10 at 01:36 PM |
I made my own - using a tube bender on a piece of electrical conduit - bent to shape,- both sides are one piece for strength - bolted through the
chassis tube front and rear - semi - circular plates welded in with a hole drilled through for the light mount then painted black. IVA friendly, and
cheap as chips - Ive got a pic somewhere....
Here you are....
![](/galpreviews/headlight mount.jpg) ![Description](/gallery/headlight mount.jpg) Description
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
