Author: Subject: IVA Fail today at Chadderton
stevegough
posted on 2/12/10 at 07:42 PM Reply With Quote
Long day,
early start
- bad start - getting it off the trailer, car went a bit quick with the snow (excuse!) jerked on the handbrake and promptly broke the left cable nipple off!!
Bottom line was that there were quite a few niggley problems, but all quite do - able:
Here's the list:
IVA Failure points:
Broken Handbrake cable (snapped it getting car off the trailer!)
Vin plate – not accessible enough. ( under nose cone).
Bias bar not lockwired.
Cover required below wiper motor.
Front top wishbone bracket – wants better edge protection.
Exhaust clamp – requires turning further in to side of car. 100mm sphere touches it.
Exhaust mounting bracket – edge to blunt and bolt end to cover. ----ditto----
Foglight lens – needs to be marked with “B” or “F” – bottom line – it must be brighter
than brakelights.
Steering column upper clamp bolts missing locking tabs.
Diff upper mount needs 4 bolts not 2.
Rear camber adjuster locknuts only hand tight – and better with 2 each side.
Uninsulated connectors – horn.
Also ‘Advisory’ points:
Wheel nuts dished washers not tight – basically the wrong wheel nuts in use.
Fuel pump relay contacts low down and pointing forward – will likely prematurely fail due to water ingress.
Mentioned during test but I think he forgot to list it….
Sierra mushroom converters require secondary locking eg. Drilling through side of upright and bolting. (In case of the pinch bolt working loose).
All in all the tester (David for those of you who know Chadderton) was very helpful, knowledgeable and also said some very complimentary things about the build quality.
Looks like a long list but I could do most of them in a couple of hours!
I'm happy
But maybe not quite this happy!!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
posted on 2/12/10 at 07:55 PM Reply With Quote
Not too bad a list , as you say you should be able to sort it out fairly quickly What cables are you using? I used unmodified Allegro cables on mine which has the independant rear end. Classic Mini's used a plastic cover over the wiper motor . I moulded a bulge on each side of the nose cone because of the exposed top wishbone mounts but I had to respray it , The upper steering column mount is secured with the original (Sierra) type nylock nuts, haven't heard you need locktabs. If you get stuck finding a wiper motor cover let me know I may?? still have one. Mel
adithorp
posted on 2/12/10 at 08:03 PM Reply With Quote
Hard luck! As you say a lot of niggly things and better the cable fails now than sometime more dangerous rather than just embarasing. None of the common bigger problems (emmisions and noise). Dave is a good guy but very thourgh. He did my SVA 2 1/2 years ago. Soon be sorted.
adrian
ps. good choice going on the trailer as it turns out.
http://jpsc.org.uk/forum/
austin man
posted on 2/12/10 at 08:04 PM Reply With Quote
I used the brass section from a terminall block on the end of the cable tightened the screws then soldered it
stevegough
posted on 2/12/10 at 08:10 PM Reply With Quote
Thanks, Mel - used the old Sierra cables - but my blobs of weld weren't too strong, I think - Allegro cables - can you still get them? Yhe cover over the wiper motor is simple - I just need a sheet of ply screwed to the underside of the glovebox - could do it asleep! The upper mount on the steering extension isn't Sierra - it has a plate right across, but the tabs which should have been there have long since snapped off - nylocks with longer bolts is probably the better option.
Want a piccy?
Luego Locost C20XE.
MikeR
Could you clarify what this means,
"Diff upper mount needs 4 bolts not 2. "
(bit worried as my diff mount is two long bolts through the diff, these both go into a large bracket either side of the diff that is bolted top and bottom onto the chassis).
stevegough
posted on 2/12/10 at 08:11 PM Reply With Quote
That sounds an easy answer! like it!
Luego Locost C20XE.
stevegough
posted on 2/12/10 at 08:22 PM Reply With Quote
Yeah, Easy one - most people (and correct me if I'm wrong) just mount the diff with the two holes through the plate on either side - I have also used the top mount which threads onto the back of the diff with a big rubber mount. This mounts to the chassis above with 4 bolts (but I've only put 2 in - hence he wants 4).
[Edited on 2/12/10 by stevegough]
Luego Locost C20XE.
mistergrumpy
posted on 2/12/10 at 08:26 PM Reply With Quote
That very fix was used on my clutch cable by a Robin Hood owner and got me the 15 miles or so home easily.
Incidentally Dave was one of the testers on my retest. He was really helpful and even let me tweek the carb settings whilst it was on the machine so that they passed.
Better fail than mine so you'll fly by next time.
[Edited on 2/12/10 by mistergrumpy]
daniel mason
posted on 2/12/10 at 08:34 PM Reply With Quote
well done steve, thats not a bad fail at all! easy fixes. whens the re test?
stevegough
posted on 2/12/10 at 08:41 PM Reply With Quote
No retest until Jan - got to earn some brownie points 'catching up' on other work I've shelved these past 6 months while I've been working on the car!! No rush anyway - they aren't winter cars are they?
More clarification photos...
Front wishbone edge covering not good enough.....
and view under glovebox showing just how easy it will be to put a cover over the wiper (I'm a better joiner than metalworker!)
Luego Locost C20XE.
stevegough
posted on 2/12/10 at 08:54 PM Reply With Quote
adrian
Yes, I agree - decent guy - I had a bit of an issue with proving engine age - I had a photocopy of the calibra's V5 with the engine number but the last 3 digits were reversed (obvious typo error) but not something I could do anything about - the car was never mine, and had been scrapped. The engine also had the date cast into the block - 05 06 90 (below engine mount but I showed him a photo) - he um ahhed a bit then said he was happy to test it to 1990 standards - phew!
Then he told me it was running lean, and showed me how to correct it! 0.54% (3.5% limit) and HC 248 (limit 1200).
As you say, good but thorough! Good point about the cable - parked on a steep hill out of gear in 6 months time it could have been dangerous or even tragic! Crossed my mind too.
Regards, Steve.
Luego Locost C20XE.
Daddylonglegs
posted on 3/12/10 at 04:31 AM Reply With Quote
Unluckcy chap. Still, as you say, could have been a lot worse and at least the tester wa civil and it's always nice when someone appreciates your hard work. Hopefully it won't be too long before you get sorted and you'll be ready for the looooooong-hot summer
richard thomas
posted on 3/12/10 at 07:19 AM Reply With Quote
Steve,
As you say - a good fail. Most of that stuff is easy enough....I'm sure you'll fly it next time!
Good luck,
Rich.
cps13
posted on 6/12/10 at 05:45 PM Reply With Quote
do you have to use the top plate as well, or do you just need 4 bolts if you use it?
Or can you get away with just the two long bolts?
stevegough
posted on 6/12/10 at 05:52 PM Reply With Quote
quoting:-
"do you have to use the top plate as well, or do you just need 4 bolts if you use it?
Or can you get away with just the two long bolts?"
You have a U2U message.
Luego Locost C20XE.
