Author: Subject: covering up exhaust flanges for iva
daniel mason
posted on 15/5/11 at 09:18 PM Reply With Quote
i have a 3 bolt flange on my exhaust collector which bolts to the pipe work to the silencer,so whats the best way to cover this for the iva? as it will probably fail om its radius! cheers
Ben_Copeland
posted on 15/5/11 at 09:22 PM Reply With Quote
Heat Shield?
Ben
Locost Map on Google Maps
Enter Your Details Here
daniel mason
posted on 15/5/11 at 10:00 PM Reply With Quote
would a heat shield work with the straps around the 3" pipe work and the center of the heat sheield on the flange
[Edited on 15/5/11 by daniel mason]
tegwin
posted on 15/5/11 at 10:10 PM Reply With Quote
Cant picture exactly what you mean, but can you get a piece of alloy/copper tube, slit it down the length and then bend it to the right radius and force it over the edge of the flange? Might not look pretty, but it should work...
I did something similar on the edge of the silencer, although it was only a thin flange i had to cover.
www.verticalhorizonsmedia.tv
coyoteboy
posted on 15/5/11 at 10:29 PM Reply With Quote
Exhaust wrap? (not sure if that's ok, but it'd be a good way of covering it with something soft and fluffy and heatproof.
daniel mason
posted on 16/5/11 at 12:15 PM Reply With Quote
to cover this
