Author: Subject: Chassis number question.
big_wasa
posted on 20/5/11 at 02:45 PM Reply With Quote
Ok I got my chassis number from dvla today, only took them a month
On the letter it says I have to get it stamped / signed of by a garage.
Whats this all about ? is this verified at iva or do I have to take it to a garage as that will be a pain in the arse.
cheers
twybrow
posted on 20/5/11 at 03:05 PM Reply With Quote
It is to verify you have had it done... Do you know a friendly mechanic? I did mine myself, wrote a letter, then asked my mechanic to sign it (I welcomed him if he wanted to come and check the chassis, but he declined!)...
adithorp
posted on 20/5/11 at 03:09 PM Reply With Quote
It'll be checked at IVA.
It might help, should DVLA want to check/inspect it themselves, if you also have a signed letter from a garage to say they've done it. Then you can argue against thier inspection... !
http://jpsc.org.uk/forum/
omega 24 v6
posted on 20/5/11 at 03:46 PM Reply With Quote
I stamped mines took pics and showed them to my friendly local MOT station. Yhey signed it off and embossed it with their stamp. Once the car was going I let them see itt alongwith the pics etc to show nothing was underhand.
IIRC the dvla also supplied the letter to be signed by the garage.
Macbeast
posted on 20/5/11 at 04:10 PM Reply With Quote
Don't see the problem.
I made up my chassis no and stamped it myself on a strip of steel which I then welded to an offside chassis member.
This number went on the application form for the IVA and it was checked by the tester. At VOSA inspection, the guy checked that the number on the chassis matched the IVA pass form. That was it.
