Bumble
| posted on 17/6/11 at 09:14 AM |
Should I cover this for IVA??
Right, IVA on Wed 22nd.....slowly ticking off the final checklist. With regard to the Innovate LC-1 Lambda probe (seen in pic) do I need to cover
this in some way for the test? I could remove it, replace with bung and wrap the whole lot in exhaust heat wrap but might need it for reference if
they allow me to tweak for emissions should it be anywhere near a pass??
Thoughts please.
Thanks,
Matt
[img]
[/img]
ashg
| posted on 17/6/11 at 01:21 PM |
heat wrap round the bung. also the wire will fail like that it needs to go through the side pannel with a rubber grommet.
on my innovate i took the plastic connector appart put the wire through the side panel then put the plug back together again so i didn't have to
make a big hole. you can get the innovate plug appart with two paper clips quite easily, let me know if you need more directions.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Bumble
| posted on 17/6/11 at 02:03 PM |
Hi Ash,
Thats what's stopped me so far from putting it through the bodywork!! Can you tell me how to get the LC-1 plug apart as that would make it much
neater.
Matt
dunk3
| posted on 17/6/11 at 02:04 PM |
Hi Matt , for the IVA i did mine like this
Better picture in my photo archive under IVA.
[Edited on 17/6/11 by dunk3]
