Bumble
| posted on 22/6/11 at 12:16 PM |
IVA Fail Today at Leighton Buzzard
Failed IVA today at Leighton Buzzard but not bad me thinks!!
Doug at Leighton Buzzard was very thorough yet fair.
1) Main Fail was Emissions. It passed Lambda at 0.998, passed fast idle 0.06, failed natural idle 4.98%!! I did notice that for whatever reason the
car was idling at 1240 rpm vs it's normal 1000 ish. Doug said it was rich at this idle so I need to check MS setting and VE table.
2) Failed on Indirect Vision - Drivers Mirror - as could not see approx the first 2 feet of the Red line at curb level seen in the picture behind the
car. I need to look at a mirror I can fit on the cage. Anyone recommend one?
[img]
  Indirect Vision
[/img]
3) Interior Fittings - Gear Lever surround does not have 2.5mm radius. See pic.
[img]
  Gearlever Surround
[/img]
4) Exterior Projections (Rear Reflectors) - does not have 2.5mm radius. See pic.
[img]
  Rear Reflectors
[/img]
5) Headlamps - The beam image kicj up was to off side. Attached is pic of the lens.....Tester thought that this was a Left Hand Drive Headlamp. Got
these yonks ago from Premier Wiring (Alan). How does this lens pattern compare to others?
[img]
  Headlamp"Kick Up"
[/img]
Only other point was that the upper ball joint threads did not go past/through the nyloc. In fact a few mm short of the nylon part of the nut.
Can't see a way round this other than different ball joints with longer threaded stud. They're for Cortin uprights by the way. Any
suggestions?
Car weighed in at 324kg front axle, 296kg rear. Initially failed brake test but after being allowed to warm the brakes in the car park the re-test
passed with flying colours. Noise was 95db. Self centering was fine.
All in all not a bad experience and Doug was very complimentary of the build quality.
Need to sort these bits out pronto and get it re-tested although off to the pub now for a well earned pint!
Thanks to all so far and look forward to your comments and advice.
Matt
PS - took the long way home....what a blast even if it was p1ssing it down.
franky
| posted on 22/6/11 at 12:24 PM |
Thats not too bad.
Longacre make a great cage mirror that lets you see about 50% more than required. I've my retest on tuesday, if it passes i'll happily
lend you my mirror for your re-test. I've filed the edges to meet radius requirements.
Daddylonglegs
| posted on 22/6/11 at 12:32 PM |
As said already, not a bad fail, should easily get it next time around
I must admit, I keep worrying about indirect vision (along with everything else about the IVA). I wish there was a diagram of the line & post
layout they use for the mirror check so we could 'practice' before the test and adjust as needed before getting to the centre.
Good luck for the re-test
Bumble
| posted on 22/6/11 at 12:46 PM |
That's a great offer.....thanks. Is that a side mirror or the rear view mirror as I already have a 14" longacre rear view mirror. Let me
know,
Thanks,
Matt
quote: Originally posted by franky
Thats not too bad.
matt_gsxr
| posted on 22/6/11 at 01:15 PM |
Not many people go to Leighton Buzzard and don't fail on some edge or another.
Sounds like a "good fail" to me. Doug is a good guy isn't he.
franky
| posted on 22/6/11 at 01:53 PM |
know,
Thanks,
Matt
Thats not too bad.
Bugger it is a rear view mirror. My testers commented on how good they were as they cover so much.
Bumble
| posted on 22/6/11 at 02:20 PM |
Thanks all the same. The longacre rearview didn't cover all the indirect field of vision but did mean that I don't need a n/side
mirror.
Do you know if Longacre do cage mounted side mirrors??
Matt
know,
Thanks,
Matt
Thats not too bad.
| posted on 22/6/11 at 02:52 PM |
Is the top BJ cone fully engaged into the upright? My nut wasn't (in fact I went as far as getting a spare nut to grind the bottom off so it
would be fully engaged into the nylon part). But when I jacked the car up via the upright and put the rattle gun on the nut it wound on nicely a bit
further until it had two threads protruding nicely.
Bumble
| posted on 22/6/11 at 03:39 PM |
Hi Ben,
Yep I've checked this already. They're fully engaged. What ball jpoints do you have?
Matt
franky
| posted on 22/6/11 at 03:50 PM |
mirror.
Matt
know,
Thanks,
Matt
Thats not too bad.
I've seen some somewhere. I welded a tab on the cage to mount normal mirrors on. Just an idea?
Michael
| posted on 22/6/11 at 04:59 PM |
I had the same trouble with the Ball joint, but noticed this before going to test (I failed test by the way)
I went and brought another ball joint and that had a longer thread. The ones i had first i brought when i started the build, but had not fitted to
the car.
daniel mason
| posted on 22/6/11 at 05:08 PM |
i have the same gear stick surround as you as well as a matching handbrake surround so i suppose im in double trouble!
any solutions to this as im awaiting iva date at the moment\?
also mk sell cage mounted mirrors. look at austin mans pics of the 2011 race car as these are the ones they sell
[Edited on 22/6/11 by daniel mason]
big_wasa
| posted on 22/6/11 at 05:13 PM |
Not bad that Matt,
Differant makes of bj seem to have differant lengths of thread. Easy fix.
Stick some half nyloc nuts on
change the joint
ream the upright / mushroom ( sierra)
[Edited on 22/6/11 by big_wasa]
Bumble
| posted on 22/6/11 at 06:04 PM |
Hi Michael,
Don't spose you know which ones you bought that had the longer thread do you?
Matt
the car.
Bumble
| posted on 22/6/11 at 06:07 PM |
Thanks Daniel.
I'll give MK a call and see what they're charging for them and how they attach. I only need the one though.
Regarding the gearstick surround if you look in my archive at the handbrake surround it's very flat in comparison to the Gearlever one. This is
fine for IVA and I have another one the same that I'll fit on the gaiter from the CBS one that failed. The tester reckoned that'd be
fine.
Hope this helps, but of you need any better pics let me know.
Matt
any solutions to this as im awaiting iva date at the moment?
Bumble
| posted on 22/6/11 at 06:08 PM |
Antone got an idea about the headlight beam issue?? How does the lens on my light compare to everyone elses?? Do you have to rotate the lens (I
thought this wasn't acceptable??).
Thanks,
Matt
stevegough
| posted on 22/6/11 at 06:55 PM |
Thanks,
Matt
Just taken this photo of mine, can't help further, the markings seem similar (but E4 instead of E10).
Otherwise, quite a 'good fail'.
I'm surprised he didn't fail you on noise - 95db is far too quiet
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Andybarbet
| posted on 22/6/11 at 08:39 PM |
Hi Bumble,
Regarding the headlights, is it worth putting another set on just to get it through IVA ??
Im only in Stevenage & have a pair of 7" black caterham headlights that you could borrow for a few weeks if need be. Im at the bare chassis
stage but picked them up a few months ago ready for when i need them.
John Bonnett
| posted on 22/6/11 at 09:00 PM |
suggestions?
An easy way to get round this problem is to turn back the face of the nut (not the nyloc end). We are not talking much here to bring the thread out an
acceptable amount. It's a common problem and you are not alone.
John
Bumble
| posted on 23/6/11 at 12:12 PM |
Further to my post yesterday and my IVA fail on headlamp beam pattern......... having spoken to Alan at Premier Wiring it is now evident that he sent
me the wrong headlamps as I have LHD lenses (there's an arrow on the lens which indicates this).
Lucky this wasn't the only fail point as I would be a tad miffed. Nevertheless Alan is sending me out new, correct lenses today so quick
fix!!
HTH,
Matt
loggyboy
| posted on 23/6/11 at 01:17 PM |
fix!!
HTH,
Matt
I thought the arrow was supposed to point to the nearside (which they do?)
Have you checked the bulb is firmly located in the right place?
Bumble
| posted on 23/6/11 at 01:38 PM |
fix!!
HTH,
Matt
That's what I thought but Alan assures me that when looking at the lens face on, the arrow should point to the left whereas mine point to the
right. I checked this with him 3 times!!
Bulbs are all correctly seated and the image kick up is the same for both headlamps.
stevegough
| posted on 23/6/11 at 01:52 PM |
Your arrow and my arrow both point the same way- to the nearside....see the two photos.
big_wasa
| posted on 23/6/11 at 02:29 PM |
^^^^^^ Same as mine aswell Matt ????
Bumble
| posted on 23/6/11 at 02:33 PM |
Steve......You didn't buy yours from Premier as well did you.........
I'm at a loss. All I know is Alan tells me the arrow should point to the left when you view the headlamp from the front. Mine point to the
right. The IVA Tester said the pattern was good just that the kick up was in the wrong direction.
I'll soon have the other set so will know more.
