gavinpurvis
posted on 26/6/11 at 08:55 PM |
Broke down any ideas
Hello
Out in the kit earlier driving along and everything went dead all electrics out. Had to get towed home doh. Checked fuses at side of the road all seem
fine, haven't had the chance to investigate yet, any ideas as to the cause?
omega0684
posted on 26/6/11 at 08:59 PM |
ran out of fuel?
RichardK
posted on 26/6/11 at 09:02 PM |
You got a kill switch that could have gone faulty, maybe a loose earth?
Rich
Gallery updated 11/01/2011
gavinpurvis
posted on 26/6/11 at 09:03 PM |
No all electrics out nothing works def not fuel
mangogrooveworkshop
posted on 26/6/11 at 09:09 PM |
The plug to the ecu could be loose ......
posted on 26/6/11 at 09:13 PM |
Are you using ZX9 electrics? It could be the 30 amp fuse in the starter relay.
Davegtst
posted on 26/6/11 at 09:14 PM |
If it's ALL electrics then it should be quite easy to find. First place to look would be the battery terminals, just because they are on
doesn't mean they are making contact. Do you have a main fuse? Battery earth? How does your positive from the battery get split up to go to
the fuse box, starter etc?
gavinpurvis
posted on 26/6/11 at 09:22 PM |
It is all the electrics, I will look tomorrow and no doubt be back for more suggestions if I'm stuck thanks for all the speedy responses. I
think the car could do with a full re wire I bought it part built. And yes it is zx9 electrics and I checked the fuse in starter relay and its not
that one.
gavinpurvis
posted on 26/6/11 at 10:07 PM |
On that topic if I decide a rewire is needed and also decide I don't have the relevant skills does anyone know any good reasonably priced places
to get a rewire?
Steve Hignett
posted on 27/6/11 at 12:13 AM |
that one.
I'm def not tryin to teach anyones gran to suck eggs, but check the "4gang" main fuse attachment. I've seen a few of those go
a bit Pete Tong in my time... As for people to rewire, get a (full, complete, intact, correct year) loom and it shoild be a piece of pee with advice
on here...
spiderman
posted on 27/6/11 at 01:08 AM |
Check the live feed from the alternator.
Spider
