johnemms
posted on 19/7/11 at 06:59 AM |
Front Brake Pipes - Again
Just looking for pics and found Bumble's IVA pass for front flexi pipes.
Any reason why I should not go the same route?
[img][/img]
cheers
Bumble
posted on 19/7/11 at 09:01 AM |
I've U2U'd you but I didn't pass IVA with them like that. I fitted new flexis from Venhill (as I changed to Wilwood calipers) and
the flexis now exit straight through the bodywork (via a rubber grommet) in line with the bulkhead fitting. Passed IVA without issue but you need to
make sure it doesn't foul on anything when turned lock to lock.
Hope this helps.
Matt
johnemms
posted on 19/7/11 at 09:56 AM |
Ahhhh... Cheers...
Looks like the way to go is to get my mild steel bracket virtualy flush with the bodywork !!
jon
Bumble
posted on 19/7/11 at 10:20 AM |
That'd be the way!!
