Relph
posted on 27/8/11 at 03:05 PM |
Help needed for 2003 R1 emissions
Hi, ive got my iva test in 2 1/2 weeks and ive just checked my emissions at a local mot test centre and the fast idle test fails. I have got a power
commander fitted and a map that someone on here passed an SVA test with, it is ok on idle but the engine runs very uneven between 2500 - 3000 which in
turn makes the emissions very unsteady.
Ive adjusted afew of the values in the map but cant seem to get both the CO and Lambda in the limits at the same time.
Has anyone got a map they have passed IVA with that they could e-mail me ? or any advise ?
Many thanks in advance.
Wheels244
posted on 27/8/11 at 03:14 PM |
I've got my map that passed SVA with U2U me your email and I'll send you it.
russbost
posted on 27/8/11 at 04:50 PM |
Just be aware that a map that works for one engine/exhaust/CAT/airbox setup won't necessarily work corrcetly for another & even things like
atmospheric pressure & humidity can have an effect when you don't have a full closed loop system. They will usually let you play with
settings at the test centre as long as you're not running out of time, but be aware that bike engines can overheat very easily when being held
at 2500/3000 rpm for the fast idle test & test centres have no additional fans etc. If the engine has a fast idle screw adjustment that is by far
the best way to get the map to work correctly as maintaining a steady throttle with a bike engine via the accelerator pedal is pretty much impossible!
Johneturbo
posted on 27/8/11 at 05:53 PM |
Getting the cat very hot is also very important
afj
posted on 27/8/11 at 06:38 PM |
I had a easy emmisions test as at the sva he let me rev the engine to 6k. But i had my emmisions set up at a local bike dyno place had aload of - 12s
and -15s in the map in 0 and5% throttle and up to 6k rpm
eerrrrrrrrrrrrrrrr
