DixieTheKid
posted on 28/8/11 at 08:58 AM |
WTD Cosworth 4x4 Throttle Body Linkage
Hello all,
Does anyone have / does anyone know where i can get the arm and spring thats attached to a Cosworth 4x4 Throttle Body? Its the arm & spring
pictured below that the thrttole cable connects to.
[Edited on 28/8/11 by DixieTheKid]
COS IT'S Worth IT
major
posted on 28/8/11 at 09:36 AM |
This guy has a complete building full of TB's, springs and Links, so perhaps he can help you with
your problem....
http://www.montronic.nl
DixieTheKid
posted on 28/8/11 at 11:50 AM |
your problem....
Nice one! ill give him a try.
COS IT'S Worth IT
BaileyPerformance
posted on 28/8/11 at 01:52 PM |
quote: Originally posted by DixieTheKid
Hello all,
The bit that attaches to the throttle body nipple comes with the throttle cable, there is no linkage or arm. All you need to do is buy a cable and
make a bracket to hold the cable. (on a cosworth the bracket is mounted on the inlet manifold) It is a simple thing, 90deg bend with square hold for
cable.
DixieTheKid
posted on 28/8/11 at 05:05 PM |
Hello all,
cable.
Ive checked that, the throttle cable comes as is. The nipple on the throttle body clips onto the cable. This is the bit i need.
COS IT'S Worth IT
