Author: Subject: advise
whitstella
posted on 15/11/11 at 08:02 PM Reply With Quote
advise
hi
right for start would/can this work, just say i was biulding a kit mainly using a sierra as a doner (so i could get the sierra plate) but i was putting a different engine in the kit, could i send off the log book and change the engine number to the other engine that i was putting in my kit????
steve
posted on 15/11/11 at 08:05 PM Reply With Quote
You could, but... there's always a but... DVLA will need a letter from a garage to say they've either installed the engine, or have inspected the engine, in the Sierra that the V5 relates to.
It's Evolution Baby!
AdrianH
posted on 15/11/11 at 08:18 PM Reply With Quote
Also you will not get the same registration from the Sierra
If you successfully get an age related plate you will be issued with just that. For Example my donor was H35 FTL, I ended up with H 123 ABC for example.
Adrian
Why do I have to make the tools to finish the job? More time then money.
zetec
posted on 15/11/11 at 08:23 PM Reply With Quote
They caught on to this long ago, I suspect also the bloke who does the test on your finished creation will know the difference between a Pinto and Fireblade engine.
Best bet if you dont fancy jumping through the hoops required with a new build is buy something already registered and on the road.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
stevegough
posted on 15/11/11 at 09:16 PM Reply With Quote
Don't quite see why you would want / feel the need to do this? I used a Sierra as my donor for the main parts and put a Vauxhall redtop in it. There was no problem getting it IVAd / registered - granted, I had a photocopy of the V5 the engine came from (mainly to prove the year for the emissions) and a reciept for the engine. I had no problem getting it 'K' registered.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
AdrianH
posted on 15/11/11 at 09:23 PM Reply With Quote
Steve you must have had enough points in the system to get an age related plate. I think it was two major components such as gearbox, brakes, differential, Engine etc.
A lot depends on the DVLA inspection. On mine at Kirham they checked all numbers against donor V5 and had a count up iof what they considered to be 'age' related.
It could also depend on what you try for!
Adrian
[Edited on 15-11-11 by AdrianH]
