Author: Subject: Edge Trim Sizes
davidimurray
posted on 22/1/12 at 11:07 AM Reply With Quote
Edge Trim Sizes
A quick question for those people who have trimmed their car - what size edge trim have you used?
Measuring my Saturn bonnet and front wings, the thickness of the fibreglass varies from about 2.5mm to 5mm.
Measuring my Triton seats, they vary from about 3-3.5mm thick.
Looking at the Woolies website - http://www.woolies-trim.co.uk/c-330-pvc-edge-trims.aspx
There generally seems to be three sizes available -
Round 0.5-3mm
Round 0.5-4mm
Square - upto 6mm edge
Are most people just using the 0.5-3mm and forcing it over the thicker bits?
I would like to use that size as I can then get some white to match my bonnet.
All advice gratefully received.
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Snuggs
posted on 22/1/12 at 11:33 AM Reply With Quote
As you are covering it with edge trim can you not just sand or file down the thicker bits ?
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
davidimurray
posted on 22/1/12 at 01:34 PM Reply With Quote
Sanding is a possibility - I am assuming other people have had the same issue so wondered what they had done.
