MattStorey
posted on 9/3/12 at 12:23 PM |
Broken Windscreen & MOT
I have a severely cracked windscreen currently which is currently due to undergo repair. Will it be a problem getting a new MOT?
It should be noted this is all on the passengers side and does not impeed my vision (but then again anything over 20mph in a type 7 everything is all
blurry anyway....)
Cheers, Matt
[Edited on 9/3/12 by MattStorey]
steve m
posted on 9/3/12 at 12:29 PM |
Take the screen off ?
its only 4 bolts on my 7 to do so
Also, i believe if there is any crack chip with in the windscreen wipe, that is a fail
[Edited on 9/3/12 by steve m]
loggyboy
posted on 9/3/12 at 12:30 PM |
40mm is the limit (outside the drivers vision) - and 10mm within.
![](http://www.windscreen-warehouse.co.uk/images/mot.png)
posted on 9/3/12 at 12:35 PM |
40mm within the swept area of the wipers isn't it?
r1_pete
posted on 9/3/12 at 12:52 PM |
I guess this would have failed then
![](/galpreviews/3Screen1.JPG) ![broken](/gallery/3Screen1.JPG) broken
But seriously, if you consider it severely cracked, so would an MOT tester and refuse you a ticket, you could always pop it in and ask the tester
before the test.
MattStorey
posted on 9/3/12 at 01:34 PM |
This is the current crack.
posted on 9/3/12 at 01:49 PM |
That will fail the MOT without a doubt. Might want to re-size that pic however.
[Edited on 9/3/12 by MikeRJ]
steve m
i would not even want to drive the car in that condition, as any small contact and the screen will be in a million pieces
And in your face
MattStorey
posted on 9/3/12 at 02:00 PM |
Thanks, this is why i am replacing it obviously, but just wanted to know if i could get it through the MOT with the crack or not.
Look's like i will be cancelling the MOT : (
Cheers.
posted on 9/3/12 at 06:38 PM |
Take it off for the MOT, simples!
MattStorey
posted on 13/3/12 at 05:52 PM |
Removed the windscreen today and MOT due on Friday. It's going to fail due to the horn not working but with lack of time i am letting the garage
doing the MOT fix the horn - Visa time...
