Daddylonglegs
posted on 30/3/12 at 10:39 AM |
Exposed Radii
I'm starting to put the last few bits of trim on the car ready for the IVA. What is the normal way guys cover up the adjustment nuts on the
tie-bars? I heard that heatshrink is no longer an option?
Also, I have made a modification to the nosecone and fibre glassed in a flat area at the bottom to put the number plate. As there is no plate at the
moment it has edges that will probably be a fail with the IVA gadget so any ideas or am I worrying unecessarily?
Thanks.
JB
designer
posted on 30/3/12 at 10:54 AM |
Shrink wrap is available but has to go on while the steering arms are dissembled. If the suspension is complete you can, like I have done, put some
central hearing pipe insulation around it.
Daddylonglegs
posted on 30/3/12 at 11:06 AM |
I did think about plumbing foam, but I thought they would complain as it is not 'permanent'?
Ben_Copeland
posted on 30/3/12 at 11:11 AM |
I don't think they allow it, suppose it depends how it's fixed and covered
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
blakep82
posted on 30/3/12 at 11:20 AM |
i seem to remember self amalgamating tape being used by people on here before?? the stuff you stretch slightly and wrap on, and it sort of melts into
itself.
can't remember the outcome at s/iva though, but i imagine it looks more permanant than most other things
or another one was (i think this is what they're called) electric cable glands? but they seem to have hexangonal nut things on them too...
________________________
tilly819
posted on 30/3/12 at 12:04 PM |
self amegameating tape is not suitable not is shrink rap as ifit were removed by a garage it would not be re fitted (one of my own iva fail points)
i used a pair of SWA wire gland covers on each of the rack adjusters (looks pucka)
and the rubber dust cover from a ball joint to cover the exposed locking nuts on the upper wishbone ball joint
both of these items can be bought from ebay for penuts
http://www.ebay.co.uk/sch/i.html?_nkw=swa+gland+20mm&_sacat=0&_odkw=swa+gland&_osacat=0&_from=R40
The black plasitc bit, (2 per side) you can get them seperatly but carnt remember were
http://www.ebay.co.uk/sch/i.html?_nkw=ball+joint+cover+&_sacat=0&_odkw=swa+gland+20mm&_osacat=0&_from=R40
and those
you can just about see what i mean in a couple of pictures on this page
http://www.haynes.co.uk/forums/showthread.php?t=6867&page=5
hope this helps
tilly
[Edited on 30/3/12 by tilly819]
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
