JeffJeffers
| posted on 18/4/12 at 09:01 PM |
Bolt length
IVA all booked for next Wednesday. Just looking over the car to make sure everything is ok.
I'm a little bit worried about the length of this bolt. Is it long enough?
There will be some pictures of the car to follow shortly!
  bolt
rdodger
| posted on 18/4/12 at 09:04 PM |
I thought it was 1 1/2 turns visible?
| posted on 18/4/12 at 09:18 PM |
Don't think that will be long enough for Mr IVA. Are all the suspension bolts the same?
Looking at the washer it looks quite thick so you might get away with a thinner washer either side to gain some thread. Might be a cheaper and
quicker fix than replacing all the bolts.
Davegtst
| posted on 18/4/12 at 09:31 PM |
Looks too short to me. I had to replace all the bolts mk supplied to 5mm longer ones. Search for thread protrusion on here.
JeffJeffers
| posted on 18/4/12 at 09:32 PM |
There not all like that most are like this. I may have bought some thicker washers! Your a genius
  bolt 2
StevenB
| posted on 18/4/12 at 09:37 PM |
stainless washers are thinner than the MS versions
s
johnwilders
| posted on 19/4/12 at 06:49 AM |
Bolt length
Are washers needed on them at all?
loggyboy
| posted on 19/4/12 at 07:22 AM |
  bolt 2
That still looks marginal...
