Author: Subject: Side Repeaters
maskell01
posted on 19/4/12 at 09:26 PM Reply With Quote
Side Repeaters
Just about to fit the side repeaters, but having fun on deciding where to put them!
I have These repeaters
not too sure on the regs/angles either!
I was planning on putting them on the side of the scuttle!
Is this wise?as im loath to start popping 20mm holes in my body pannels to find they are wrong!
Aaron
big-vee-twin
posted on 19/4/12 at 09:30 PM Reply With Quote
Most fit them on the front cycle wings as the rear wings obstruct the view of them from the rear.
Some put them on the rear wings.
But as I understand it on the Scuttle is an IVA fail.
http://www.triangleltd.com
L5W
posted on 19/4/12 at 09:33 PM Reply With Quote
I have those repeaters and fitted them to the rear arches. The IVA tester at Norwich was fine with the position, all he checked were that they were within the 2.6m distance limit from the front of the car
Lee
loggyboy
posted on 19/4/12 at 10:08 PM Reply With Quote
Putting them on the skuttle means rear arch blocks them for the 5degree rearward viewing angle. Putting them on the front arches means 'some' inspectors will argue that when on lock, they also cant been seen from the 5degree viewing angle. So the safest place is rear arch, then relocate to skuttle - which is IMO, the safe place to have them, as they may pass on the rear arches, but they arent in the best position for viewing from a practical point of view, ie along side some one they could end up in their blind spot.
handyandy
posted on 19/4/12 at 10:09 PM Reply With Quote
I have the same side repeaters & have also fitted them to my rear arches as Lee above.
chers
andy
big_wasa
posted on 20/4/12 at 07:03 AM Reply With Quote
As above and they are easier to wire up.
nige
posted on 20/4/12 at 11:09 AM Reply With Quote
heres what ive done
side repeater 1
side repeater 1
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
loggyboy
posted on 20/4/12 at 12:02 PM Reply With Quote
Originally posted by nige
heres what ive done
side repeater 1
side repeater 1
Superb and neat idea. Do you defo get 5 degrees past the rear arches?
nige
posted on 20/4/12 at 12:51 PM Reply With Quote
ive not measured it , but they can be seen from a good field of view
and are above the line of the rear arch
