Author: Subject: Carbs and IVA
austin man
posted on 3/5/12 at 08:53 PM Reply With Quote
Carbs and IVA
Would a 1995 pre august engine get through the IVA with Carbs fitted or is it a deffinite fail
blakep82
posted on 3/5/12 at 08:59 PM Reply With Quote
of course it can. as ong as any emissions are met etc.
why would it be a definite fail?
pinto engines with carbs still go through
________________________
austin man
posted on 3/5/12 at 09:14 PM Reply With Quote
I wasn't sure if the cut of date has changed, SVA the cut of dat was august 95 anything after needed a CAT and tested on hydrocarbons etc.
blakep82
posted on 3/5/12 at 10:55 PM Reply With Quote
in any case you'd have to prove engine age, and it would have to meet emissions from that time, cat would be needed for post august 1995 engines, but as long as the carb was standard fitment, there shouldn't be an issue
