Author: Subject: Covering the Wiring
mad4x4
posted on 4/9/04 at 07:28 PM Reply With Quote
Covering the Wiring
Do I need to cover or wrap the wining loom in something?
Can I use insulating tape?
Do I need to wrap all wires?
Scot's do it better in Kilts.
posted on 4/9/04 at 08:41 PM Reply With Quote
As per your description, can't you just buy a wooden rack to store the bottles?
Seriously though - we use flame retardent insulation tape on almost all the wiring. Some have used spiral wrap or even a semi-rigid conduit.
wilkingj
posted on 4/9/04 at 08:42 PM Reply With Quote
You cant just use tape. Its must give some physical resistance to abrasions / damage.
You can use:
Split convaluted tubing
The hardish nylon expanding tube like a sort of net / hose.
GeoffW
Spirobind / spiral wrap, but this needs not to have nay gaps between the windings.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 4/9/04 at 10:16 PM Reply With Quote
I used tape on mine.
Not adhesive though, it was just black non adhesive about 2"wide, loom wrap from one of the electrical suppliers. Just use adhesive to secure the ends.
mangogrooveworkshop
posted on 4/9/04 at 10:52 PM Reply With Quote
Ah thats the u2u convoluted tubing is good
RoadkillUK
posted on 5/9/04 at 01:30 AM Reply With Quote
I've used a combination, semi-rigid conduit (split) in the engine bay and from front to back, behind the dash etc. I have reused the original non sticky tape.
HTH
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
mad4x4
posted on 5/9/04 at 09:04 AM Reply With Quote
Behind the DASH ? All my wiring is held every 2-3" with cable ties in a very tight panel wiring style of loom ( can't move) do I need to wrap this or is it just the engine bay and the read quarters(i.e exposed wires)?
[Edited on 5/909/04 by mad4x4]
wilkingj
posted on 5/9/04 at 07:37 PM Reply With Quote
Yep... Errr Sorry... I was referring to Adhesive tape.
Geoffw
Best Regards
Geoff
