Author: Subject: iva and registration
tcr
posted on 8/9/12 at 03:00 PM Reply With Quote
applying for the iva soon but i was wondering is there a time limit from passing iva to registering the car as i was going to wait till the new reg comes out to put it on the road .
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
Mark Allanson
posted on 8/9/12 at 03:11 PM Reply With Quote
Didn't the new reg come out 8 days ago?
tcr
posted on 8/9/12 at 03:21 PM Reply With Quote
due to a dvla restriction i cant drive till feb but i still want to get the car iva'd in case it fails
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
wilkingj
posted on 8/9/12 at 03:58 PM Reply With Quote
If you cant drive it until Feb,
IVA it, register it, and then SORN it.
It will only matter (and only a small amount) if you want a new 12/62 reg.
Just my 2d's worth.
Best Regards
Geoff
http://www.v8viento.co.uk
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 8/9/12 at 05:56 PM Reply With Quote
Won't you be on a Q plate?
If not, you and I need to talk since mine is being IVA'd soon and I wouldn't mind a new 12 reg on mine.
Let me know.
tcr
posted on 8/9/12 at 07:02 PM Reply With Quote
i cant drive the car till the new reg comes out so i cant see the point in having it road legal , when i do finally get to drive it it will already be 6 months old. cant see why it would be on a Q-plate unless you know something Ive missed.
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 9/9/12 at 07:18 AM Reply With Quote
I'm no expert here - ive yet to IVA and register my car, so need some other people who have been through this process to chip in.
I was under the impression that if you could prove the registration of the donor car you could take forward the registration from this car, if you can't you get a Q plate and not a "year plate"
However, what if you have bought all new parts for your car - doesn't this entitle you to a year plate?
I know there is a section on the IVA application form where you can provide receipts - does this have anything to do with the application of a "year plate"?
Can someone clear this up for us please?
Acc8braman
posted on 9/9/12 at 10:54 AM Reply With Quote
1) If you can prove enough components from one donor and you have the v5c, you will get its reg.
2) If you use brand new parts and provide evidence, then you will receive a new year plate.
3) If you cannot identify the source of parts, then you will receive a Q plate but the DVLA try to avoid issuing a Q plate if they can
tcr
posted on 9/9/12 at 11:01 AM Reply With Quote
my midi was built using all new parts apart from the engine and Ive got receipts for everything
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 9/9/12 at 11:27 AM Reply With Quote
Does a recon part constitute a new part? If not, what did you do about the steering column and rear diff?
tcr
posted on 9/9/12 at 12:03 PM Reply With Quote
The column was made at mk engineering and the diff is a new fiesta unit in a housing also made by martin
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
Barkalarr
Contributor
Posts 942
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 9/9/12 at 09:23 PM Reply With Quote
Is that a sierra column or a custom made one? Can you shoot a picture of it please?
adithorp
posted on 9/9/12 at 10:00 PM Reply With Quote
I think you're allowed 6mths between passing IVA and applying for registration.
What plate you get is down to DVLA and nothing to do with the IVA (VOSA).
You can get a new plate provided all major components are new (with reciepts) with the exception of one component which must be "reconditioned as new" with proof.
You get an age related plate if you have enough components from one donor car and the v5 from that car. Age related plates are the same year designation as the donor, not the same reg' as the donor.
If you don't meet one of the above you get a Q.
http://jpsc.org.uk/forum/
tcr
posted on 9/9/12 at 10:11 PM Reply With Quote
thanks thats cleared that up
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
tcr
posted on 9/9/12 at 10:21 PM Reply With Quote
its a custom made column
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
