subk2002
posted on 15/9/04 at 04:15 PM |
Emmision additive??
Is there somthing i can put in the fuel to help me get passed the emmisions test??
Drew
Mk-Ninja
posted on 15/9/04 at 04:51 PM |
I asked the same question a while ago. No answers unfortunatly, but if someone came up with something it would be worth a fortune
I'm sure I've got one, just don't know where I've put it
dmottaway
posted on 15/9/04 at 07:07 PM |
denatured alcohol - contains lotsa oxygen. put in enough to make about a 10-20% mixture in you tank. find it in the paint supply section.
also retard you timing a couple of degrees - keeps combustion temps down to minimize the NOx emissions
dave
[Edited on 15/9/04 by dmottaway]
Viper
posted on 15/9/04 at 07:15 PM |
U2U Avoneer, i seem to recal he said he used something for this ...
andyps
posted on 15/9/04 at 09:36 PM |
I was advised by my MOT tester a few years ago to use something called "Add-it" to reduce the emisions. I never actually bought it - seem
to remember he gave the certificate anyway I was a very good customer at the time - it was where I got my company car serviced about every 6
weeks!
Mark Allanson
posted on 15/9/04 at 09:59 PM |
Peugeot sell a diesel additive called Forte, there may well be a petrol version too
scotlad
posted on 15/9/04 at 10:09 PM |
good luck tomorrow Drew- it'll be your car at knockhill next time!
posted on 17/9/04 at 05:14 PM |
Ask for Forte Gas treatment, think that is what you want, best of luck. Rusty
subk2002
posted on 17/9/04 at 05:49 PM |
I got something but its not FORTE.I does say on the bottle it will reduce emissionsJust what im looking for
Avoneer
posted on 21/9/04 at 03:45 PM |
Add It
That's the stuff I used. Brought my CO2 down from 3.7 to 0.9. Also dissolved all the rust in my Tiger supplied tank to sludge and blocked my
fuel filter, but passed the emissions anyway...
Pat...
Jeffers_S13
posted on 1/10/04 at 12:10 PM |
Will this stuff work on modern cars, with a CAT, without problems ? I need to get my mates M reg Festa through, its just over the limit. Faffed
around doing an engine swap and various other stuff, runs ace but failed on emissions
James
subk2002
posted on 1/10/04 at 05:28 PM |
Yes it will do the trick
