Author: Subject: Brake warning lamps
pekwah1
posted on 18/10/12 at 11:03 AM Reply With Quote
Brake warning lamps
Hi Guys,
For IVA do you HAVE to have warning lamps for the handbrake and brake failure?
Regards,
ANdy
loggyboy
posted on 18/10/12 at 11:07 AM Reply With Quote
Its fairly complex, but the easiest explanation is you need a fluid level sensor which triggers the warning light, this also needs a test switch, this can be combined with the handbrake warning light, but you dont NEED the handbrake warning light if you have a seperate 'brake test' switch.
Mistral Motorsport
