Jenko
| posted on 26/12/12 at 09:39 PM |
Seat fixing and iva.
I want to bolt the seats direct to the floor of my sylva j15, however, I also want to recline the seat back which means the front needs to be elevated
around 50mm.
The bottom of the seat has a captive nut built into it (m8), using some large cotton real rubber mounts seems like a good idea...I can't see any
reason in the iva manual not to use them....but would appreciate thoughts on this.
[Edited on 26/12/12 by Jenko]
MY BLOG - http://westfieldv8.blogspot.co.uk/
ReMan
| posted on 26/12/12 at 10:15 PM |
I see no reason why not, as long as it's fully secure.
Presumably will use the same chassis mount point s anyway so should be fine
www.plusnine.co.uk
snapper
| posted on 27/12/12 at 07:31 AM |
I would worry about the cotton reel shearing in an accident
Perhaps some 50 x 25 square tube across the two seat mount holes with a bolt through the floor and a load spreading washer under the floor would be
more IVA compliant
[Edited on 27/12/12 by snapper]
I eat to survive
I drink to forget
avagolen
| posted on 27/12/12 at 01:51 PM |
I thought that the seats had to be adjustable on new builds?
Confused.
loggyboy
| posted on 27/12/12 at 04:58 PM |
Confused.
They have to adjust if they were designed to be adjustable, ie if you fitted seat runners they would need to work. If the car was designed with a
fixed seat its ok.
Mistral Motorsport
loggyboy
| posted on 27/12/12 at 05:05 PM |
Seat does very little in an accident (in a seven at least) as theres no where for it to go. I would be more worried about them sheering under general
use and doing very little anyway. Just bolt them straight up.
Mistral Motorsport
Jenko
| posted on 27/12/12 at 06:13 PM |
My understanding about the seats (as mentioned), is if you have runners they must work in three positions, if they are fixed, then there is no
adjustment to test.
Re the rubber mounts...they seems to last well for the exhaust and even engine, so would thinkt they would be ok.....plus as I understand t they are
very strong...I'm talking about the m8 bolts and 40mm dia ones, not the small ones.
loggyboy
| posted on 27/12/12 at 08:32 PM |
I just cant see what advantage the rubber mounts would give. Other than spacing, which could be achieved with washers.
Mistral Motorsport
Jenko
| posted on 28/12/12 at 02:47 PM |
No advantage...but the front of the seat needs raising around 50mm... That would take a lot of washers, plus,as the front raises up the angle from the
bolt through the floor would become more, the rubber means you could account for this. It just seems to offer a cheap, light, simple solution.
hellblue
| posted on 28/12/12 at 09:48 PM |
Maybe its just me ? but if you plan on a retest then go ahead with the rubber mounts !
RS1 ....
Every seat must be securely attached to the vehicle structure, or other obvious suitable load bearing parts of the vehicle
via a bit of rubber, i would suggest falls very short of the above !
[Edited on 28/12/12 by hellblue]
ReMan
| posted on 28/12/12 at 10:12 PM |
Well that told us.
You better get the welder out!
www.plusnine.co.uk
loggyboy
| posted on 28/12/12 at 10:34 PM |
RS1 ....
I would imagine the engine, exhaust and fuel pump needs to also be securely attached to the vehicle structure, but they're not failed on being
mounted on rubbers!
Mistral Motorsport
Jenko
| posted on 29/12/12 at 08:03 AM |
It's a good point and this is why I posted.....what defines securely? I would suspect the rubber mounts are very strong, but what defines
securely.
loggyboy
| posted on 29/12/12 at 09:21 AM |
Secure would be anything that is unlikely to fail under the stresses of normal use and time. I think the rubbers providing they were not too small,
would pass IVA, however I would expect a aluminium spacer would be lighter and better option. As I would want to feel things through my seat, not have
things isolated/insulated. It mayu also lead to some movement under heavy load which might feel weird or confuse the sense
Mistral Motorsport
ReMan
| posted on 29/12/12 at 09:27 AM |
I think that the cost/weight/benefit is probably the biggest driver and I 'd agree that if a bit of ally would do it then save the expense of
the rubbers unless you've got a bucket of them
www.plusnine.co.uk
907
| posted on 29/12/12 at 09:52 AM |
I would have thought that the simple solution would be to bolt a couple of pieces
of box to the seat, then bolt the boxes to the floor. (see pic)
Paul G
Slimy38
| posted on 29/12/12 at 10:51 AM |
Taking that a bit further, if you consider your body weight while cornering, the rear solid fixings would have to accept the (slight) movement of the
front rubber fixings. That could lead to early weakening or failure of the rear fixings.
If you compare it to an engine rubber mount, they're all rubber so they can all move as the engine moves.
I'd say the seat fixings need to be all flexible (which I would expect to be an IVA fail?) or all fixed.
