theduck
posted on 6/1/13 at 07:52 PM |
Toggle switches and IVA.
Will a car pass IVA if using something like these with toggle switches?
http://www.cbsonline.co.uk/product/Toggle_Switch_Guard_SWGUARD
Would like to use them as I like the look but will use an IVA safe switch set if not.
snapper
posted on 6/1/13 at 07:59 PM |
Only if you use the metal U protectors otherwise there to pointy
I eat to survive
I drink to forget
avagolen
posted on 6/1/13 at 08:03 PM |
Yes, as long as the radius is 2.5 mm (5mm OD).
If you need 5, they are cheaper from the USA. -
( Unless the customs get hold of them and charge you import duty.)
HTH.
Len.
switch panel
This is my panel using the USA items.
[Edited on 6/1/13 by avagolen]
blakep82
posted on 6/1/13 at 08:04 PM |
Mmm, not quite. There's an area behind the steering wheel where you can put them without issues.
________________________
theduck
posted on 6/1/13 at 08:17 PM |
Cheers. Thinking of using the switch surrounds from a modern mini.
Charlie_Zetec
posted on 6/1/13 at 10:58 PM |
I've got a "spare" set of modern mini-type switches - it's the mini surround and loops that i removed and sprayed plain black,
but with illuminated toggle switches (*two green, one blue and three red from memory*) in place of the silver OE items. I decided to change to savage
switches instead, if you're interested? Only really after what it owes me, happy to send you some pics if you like....
Davegtst
posted on 6/1/13 at 11:11 PM |
This is my dash with those switch guards fitted. You can get them from this guy in the states alot cheaper than cbs and they are the exact same
thing. Go for the polished $6.99 ones as the $6.00 ones are only 4mm wide and will fail the radius test.
http://www.periheliondesign.com/switchguards.htm
franky
posted on 6/1/13 at 11:14 PM |
yes they did but I didn't waste my money with the robbers at CBS
Just look at U-bolts, I think mine were about £1.50 each.
theduck
posted on 6/1/13 at 11:15 PM |
U2u sent Charlie.
