MsD
posted on 2/3/13 at 01:37 PM |
Handbrake warning light.
Hopefully a nice simple question...
Is a handbrake warning light required for IVA?
I have a lowfluid level light already wired in.
Thanks, Mark.
posted on 2/3/13 at 01:38 PM |
Yes, its required, in that its a low fliud level warning and, needs a test switch.
The switch on the handbrake acts as the test switch.
[Edited on 2/3/13 by coozer]
MsD
posted on 2/3/13 at 01:48 PM |
Thanks. Ill get it wored in then!
I presumed they removed the brake M/C cap to simulate there being no fluid in there? and tested it that way?
Mark.
twybrow
posted on 2/3/13 at 02:02 PM |
No is the actual answer - you don't need a handbrake mounted switch, but you do need a way to test the lamp from the drivers seat - the standard
way is to have it on the handbrake. You can mount a switch on your dashboard to test the low brake fluid light - it is not a handbrake warning light!
loggyboy
posted on 2/3/13 at 02:13 PM |
This.
Mistral Motorsport
twybrow
posted on 2/3/13 at 02:14 PM |
This.
.... Is there more to come from you there Loggy?!
posted on 2/3/13 at 02:32 PM |
Classic minis had a non latching switch on the dash to test the warning light. The switch does have to be labelled correctly. You can check if the
handbrake is on by looking down at it
[Edited on 2/3/13 by Peteff]
MsD
posted on 2/3/13 at 02:33 PM |
Thanks for your help guys.
another job to add to the never ending list... at least its only a quick one!
Mark.
40inches
posted on 2/3/13 at 03:30 PM |
Having a starter button, I used the start position on the column ignition switch as the test switch
Although, reading the manual, it seems that if you can see the level through the side of the fluid tank, you may not need
a warning lamp. ISTBC
loggyboy
posted on 2/3/13 at 04:18 PM |
there is a second part later on about pressure loss, which either needs a pressure warning light or a level warning light (based on if pressure drops,
fluid level will drop)
Mistral Motorsport
renetom
posted on 2/3/13 at 06:49 PM |
Hi
We used a Savage illuminated momentary switch
& this is how we wired it, Iva man tested it & was happy.
The light comes on when you press the switch, when the handbrake is on
& when the fluid level drops.
Good luck
René
loggyboy
posted on 2/3/13 at 06:55 PM |
quote: Originally posted by renetom
Hi
Good luck
René
Seems a little overkill, just a bulb alone would have sufficed with the handbrake acting as a switch.
Mistral Motorsport
renetom
posted on 3/3/13 at 09:38 AM |
Fine if you don't need to go through IVA, (Handbrake is not a test switch)
But we wanted to do it correctly rather than a bodge.
theduck
posted on 3/3/13 at 10:55 AM |
Handbrake switch IS a test switch, says so in IVA manual iirc. Certainly never read of anyone having to fit a seperate switch!
The Black Flash
posted on 4/3/13 at 11:31 AM |
Yup, as someone already said above.
You need a switch to test the bulb. This can be either a dashboard switch, OR one on the handbrake. You don't need a separate "handbrake
switch".
adithorp
posted on 4/3/13 at 12:14 PM |
As a general rule, if you do something the same way major manufactures do it, it'll pass IVA. Don't know any current tin-tops that
don't use the handbrake switch as a test switch for fluid level.
http://jpsc.org.uk/forum/
iank
posted on 4/3/13 at 12:28 PM |
IVA manual doesn't require there to be a switch, as it refers only to a "test facility" for the warning lamp.
quote: Hydraulic and Vacuum Systems 09D Required Standard 18
Where a warning lamp is provided as the only means of checking
the fluid level without opening the reservoir, it must be secure,
operational, visible during daylight and darkness from the driving
position, and fitted with a “test facility” that enables its operation to
be checked from the driving position without opening the reservoir.
Handbrake switch is fine, switch on the dashboard (like the old mini) is fine, you could also arrange an automatic test for one second after ignition
is switched on.
Anonymous
Jimfin
posted on 4/3/13 at 09:04 PM |
I opted for the simple dashboard switch as - being a classic locost - the escort doner did not have a handbrake switch! So this was easier than
b******* about with springs and stuff.
To answer another question raised by Mark, the method of testing at my IVA was to depress the test "button" which is built into the cap on
top of the reservoirs in turn - the tester watched the light come on appropriately.
