skov
| posted on 25/5/13 at 10:58 AM |
Another load of pre-IVA pics!
Hi All,
I sent my IVA application off this week. Can you take a look at my pics and see if there's anything I've missed.
Click Here for Photos
Thanks,
Skov
[Edited on 25/5/13 by skov]
| posted on 25/5/13 at 11:06 AM |
Link not found
skov
| posted on 25/5/13 at 11:24 AM |
oops, had the album set to private! Hopefully fixed now.
theduck
| posted on 25/5/13 at 12:24 PM |
Reposition harnesses so they don't run through the seats, as they are will fail IVA.
Not for IVA, but those wheels look very tucked in at the back!
skov
| posted on 25/5/13 at 01:04 PM |
Hmmm, those rear wheels do look a little odd now you mention it!
Might have to add that to the list of jobs over the winter.
Why would the harnesses going through the seats be a fail?
carlknight1982
| posted on 25/5/13 at 04:24 PM |
They shouldn't mine didn't here is a photo taken while my Iva certificate was being written
  Front Finished
Logic will get you from a A to B
Imagination will take you everywhere.
renetom
| posted on 25/5/13 at 04:41 PM |
Hi
Our belts go through the seats & passed Ok.
does the silencer have a cat , have you checked the emissions ?
Good luck.
Russell
| posted on 25/5/13 at 06:35 PM |
Is that battery clamped in place or just pushed into the cage? If not retained in place it could move forward under braking.
Russ
I'm a bilingual illiterate. I can't read in two languages.
loggyboy
| posted on 25/5/13 at 06:49 PM |
Going through the seats is fine, but the mounts need to be positioned so that the harness doesn't pull against the seat frame when you are
wearing them. Yours look fine.
[Edited on 25-5-13 by loggyboy]
Mistral Motorsport
skov
| posted on 25/5/13 at 08:06 PM |
Thanks for the replies so far!
Hopefully be alright with the seats/belts by the sound of it.
I can't easily check the emissions, but they should be ok. I don't have a cat fitted, but the engine is old enough for a non-cat test,
and I'm running the OEM ECU so I recon I stand a good chance of getting through.
The cage is bent over the battery front and rear, so it can't slide anywhere.
Do the IVA covers on the front suspension look ok?
adithorp
| posted on 25/5/13 at 09:35 PM |
As long as the belt mountings are higher than the bottom edge of the seat holes you'll be OK. If they're not just use longer bolts and
spacers to raise them.
Do you have evidence of the engine age. They'll want written proof.
http://jpsc.org.uk/forum/
skov
| posted on 25/5/13 at 10:46 PM |
I'm pretty sure the mounts are slightly higher, but I'll check next time I'm in the garage.
Mazda charged me £35 to send me a letter stating when the engine was made. Worth every penny if it means I don't have to fit a cat
SteveWallace
| posted on 26/5/13 at 07:34 AM |
Nice build and good luck
Does the lower edge of the bodywork (side panels and rear tub) meet the external radius requirements? I have a feeling that it is supposed to these
days.
By the way, what have you used to cover your upper seat belt mounts - they look good and I would like to do something similar with mine.
skov
| posted on 26/5/13 at 10:10 AM |
days.
Thanks Steve,
I knocked up the seat belt covers one evening on my sewing machine
They're made out of vinyl with scrim foam glued on the back and bias binding sewn down the edges.
I used press studs to hold them on:
I think you're right about the bottom edges. I think mine are mostly ok, but I'm sure there's a couple of places that need
smoothing out.
baz-R
| posted on 28/5/13 at 08:56 PM |
looks good i see the mx5 roadster has quiet a few thing diffrent.
have you checked sound on that exhaust? i got 95db on somthing twice the size
skov
| posted on 28/5/13 at 11:15 PM |
Yes, it was 110dB!
I managed to get it down to 96 with the creative use of some wire wool though
