avagolen
| posted on 8/6/13 at 07:38 PM |
Lucas 488 lights IVA OK?
IVA question.
Does anyone know If these Lucas lights will pass the IVA test?
Thanks in advance.
Len.
adithorp
| posted on 8/6/13 at 09:23 PM |
Should be fine for side/indicator/brake with the right coour lens and bulb wattage. Won't do for fog though.
http://jpsc.org.uk/forum/
avagolen
| posted on 9/6/13 at 06:43 AM |
Thanks, I am hoping to use them for reversing lights.
matt_gsxr
| posted on 9/6/13 at 08:42 AM |
As you at the design stage I am fairly sure you only need one reversing light (if that helps).
Similarly only one fog light (must be central or side nearer to the centre of the road).
Worth checking against the manual.
Matt
jacko
| posted on 9/6/13 at 05:06 PM |
  rear of my indy
Thats what i have fitted they where ok for SVA if that helps not IVA
as you can see i have two reverse lights the reason was that i would make one a fog light after the teat [ but never did ]
and fitted the big fog light insted
Jacko
avagolen
| posted on 9/6/13 at 06:07 PM |
Thanks Guys.
The reason I would like to fit 'small' reversing lights - 2 off - is that I do not want to fit the
original ones I purchased (which are the same size as the other lights already fitted) as they
just look 'to much' for the style I am trying to design into the rear of the car.
I want to fit one either side of the fog light and keep the overall layout balanced.
This is the view so far. (I cannot get a bigger picture as the wall is still in the way )
Len.
