Author: Subject: setting headlight alignment
davidimurray
posted on 19/7/13 at 08:24 PM Reply With Quote
Working through finishing jobs for iva. Have had a read of the iva manual and the process makes no sense to me! Can anyone tell me how I can setup my headlights at home?
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
big-vee-twin
posted on 19/7/13 at 08:47 PM Reply With Quote
I am planning a visit to my local mot station to set the brakes, headlamps, tracking and test emissions prior to the IVA.
http://www.triangleltd.com
matt_claydon
posted on 20/7/13 at 09:33 AM Reply With Quote
Park on a very level surface facing a wall or vertical board. Measure the distance from the headlamp lens to the wall (eg 5m) and work out 1.5% of this (eg 75mm) (or whatever beam angle you are aiming for). Measure the height of the lamp centre, or better still put a piece of paper on the lamp and see where the beam cutoff is (eg 500mm). Make a mark on the wall at this height, minus the figure you calculated earlier (eg 425mm).
If you adjust the beams vertically so that the horizontal cutoff is at your mark, you will have -1.5% inclination. Horizontally, the lamp's 'kickup' should be straight ahead of the lamp.
davidimurray
posted on 20/7/13 at 10:10 PM Reply With Quote
Thanks Matt
That's great - makes more sense now.
Dave
daveb666
posted on 21/7/13 at 10:00 AM Reply With Quote
Tester let me do mine on the day - I think they understand there's only so much you can against a wall.
40inches
posted on 21/7/13 at 10:26 AM Reply With Quote
