Sloan85
posted on 2/9/13 at 09:24 PM |
Is the upper ball joint radius tested on an Indy?
I have protected the locking nut but done nothing with the ball joint as I was told it was not tested. I have read a few conflicting things on the
forum tonight so was hoping someone can give me an up to date answer? Would the upper ball joint be radius tested on an Indy.
http://mkindygsxr.blogspot.co.uk
Mr Whippy
posted on 2/9/13 at 10:01 PM |
I have certainly thought so, if it has a sharp edge you can fill a radius on the edge quite easily. Same applies to the uprights as they tend to be
cast quite crudely due to usually being completely hidden.
doobrychat
posted on 2/9/13 at 10:26 PM |
image would be good..
i used a rubber kit from ebay to cover my nut and my ball joint is exposed and no issues with my tester and he didn't get the radius tool out on
mine at any point..
Sloan85
posted on 3/9/13 at 05:31 AM |
Sloan85
posted on 4/9/13 at 01:01 PM |
Sorted this issue last night with some 40mm cable gland shrouds
