Author: Subject: Re-shelling a car...which VIN, V5 etc?
posted on 8/11/13 at 10:02 AM Reply With Quote
Tried searching, but not finding what I'm after!
If you re-shell a car, i.e. take a shell that's V5 registered and declared SORN and transfer all the running gear, interior etc from another V5 registered car, which identity does the resulting vehicle take?
Ideally I'd like to retain the identity of the original vehicle and not the new shell. Can this be done by changing the VIN on the original V5?
loggyboy
posted on 8/11/13 at 10:11 AM Reply With Quote
Started again because of thoroughly confusing myself!
You need to have a brand new shell.
https://www.gov.uk/vehicle-registration/radically-altered-vehicles
Mistral Motorsport
posted on 8/11/13 at 10:20 AM Reply With Quote
OK - so it would have to take the ID of the shell being used. I guess then its a case of getting the engine no. changed on the V5.
loggyboy
posted on 8/11/13 at 10:30 AM Reply With Quote
yes, but you technically would also need 3 points from other items (ie steering & suspension) HOWEVER as it looks the same on the outside, I doubt anyone would notice if it was just the shell.
and yes (if you want to be 100% legit) but ive never updated engine numbers on the countless cars ive changed engines on and its never been an issue, even when it came to insurance claims (providing the engine size is same).
Mistral Motorsport
posted on 8/11/13 at 12:11 PM Reply With Quote
Agreed, suspension, axles steering etc would all be identical anyway and are not serial numbered in any case. The engine no. change would really be to keep things in order should the car be sold.
mcerd1
posted on 8/11/13 at 01:34 PM Reply With Quote
as above once a shell has been registered it'll keep that id till its scrapped
sounds good to me ....besides there is no law against replacing any number of worn out parts with either new or second hand ones
you could do a cherished transfer to keep the reg. number - but the old shell would need an MOT for that....
[Edited on 8/11/2013 by mcerd1]
posted on 8/11/13 at 06:31 PM Reply With Quote
It has one now, but the next one might be a challenge
[Edited on 8/11/13 by nick205]
mcerd1
posted on 9/11/13 at 12:20 AM Reply With Quote
get the plate off it now before the MOT runs out (doesn't cost much to keep it)
then transfer it onto the other one once its rebuilt
[Edited on 9/11/2013 by mcerd1]
