JMW
posted on 19/5/14 at 02:27 PM |
Certificate of Destruction
Apologies if this is the wrong forum:
My road-going narrow-bodied Westfield suffered significant chassis and
panel damage at a recent hillclimb. I don't think it is economic
to repair now, especially as I want a full cage in future when I compete (it
currently has a roll-over bar).
My question is: is there a way to get a certificate of destruction issued for
it, by just giving up the bits I don't want,e.g. chassis, bodywork and
allowing me to keep the elements I do want, e.g. engine, gearbox, lsd,
brake calipers etc?
tegwin
posted on 19/5/14 at 02:34 PM |
Is it road registered...in which case simply fill in the part of the V5 that says it has been scrapped and chop the car up..
It's an expensive process getting the V5 in the first place so It might make more sense to repair the car and retain its ID!?
www.verticalhorizonsmedia.tv
JMW
posted on 19/5/14 at 02:48 PM |
Yes, it is road registered, taxed and MOT'd (but won't pass next time!).
I thought the problem was that you can't scrap a car yourself anymore,
that it either has to be a) taxed, b) SORN'd or c) be the subject of a
Certificate of Destruction issued to you by an Authorised Treatment Facility (ATF).
Have I made it more complicated than it needs to be?
dhutch
posted on 19/5/14 at 03:08 PM |
I would have a chat with the local breakers.
Sounds reasonable to me, when I wrote of one of my 306's and broke it for bits I look basically everything off it, and then signed over the
shell and got the v5 stamped and signed.
Daniel
JMW
posted on 19/5/14 at 03:13 PM |
Does anyone know of a breakers in the Northwest likely to be amenable to this sort of request?
loggyboy
posted on 19/5/14 at 03:18 PM |
They will let you scrap a car yourself, just fill in the V5 and add a covering letter saying how and why it was scrapped by you only.
If you buy a new chassis from westfield uou could be able to reshell and keep the existing ID to save on IVA expense etc.
[Edited on 19-5-14 by loggyboy]
Mistral Motorsport
sdh2903
posted on 19/5/14 at 03:19 PM |
I may very well be talking out my hole, but if you replace chassis like for like can you not retain the v5? Or are you building a different car?
ReMan
posted on 19/5/14 at 03:23 PM |
As with sevens it seems acceptable to replace the chassis, like for like and it not be "ringing", I'd have thought that you would
not want to scrap it?
Presumably not an insurance claim on a hillclimb?
So I'm sure there is considerable worth in it even if you bought a new chassis (with rool cage) and body and then "upgraded the bits you
didnt want, or other combinations as suits?
www.plusnine.co.uk
JMW
posted on 19/5/14 at 03:31 PM |
thanks for all the responses. Yes, no insurance involved. It would be a new shell as well as a new chassis. I'm not sure
I'm up to building another car at present, but if I did I'm presuming from your responses that the DVLA don't mind being
informed of a changed chassis number?
Loggyboy - on scrapping it yourself, sorry to query, but are you sure you can just fill in the V5 and put a covering letter with it?
Has this worked for other people? I thought there was a £80 fine involved.
adithorp
posted on 19/5/14 at 03:53 PM |
If you replace the chassis with an "identical replacement" then you can (legally) transfer the old chassis number and registration to the
new chassis. As there is no official record of exactly what the old design was, then slight differences will go un-noticed... especially as
there's no requirement to show it to anyone as it's not been officially written-off. New for old
Westfield chassis will be fine. Personally thats what I'd do but I wouldn't advertise it to the whole world.
You can replace any (damaged or otherwise) body work you like. If you're not sure about rebuilding strip off what you want to keep, cut up and
weight in the rest and put the car "officially" on sorn until you decide
http://jpsc.org.uk/forum/
mcerd1
posted on 19/5/14 at 04:00 PM |
new chassis.
^^ worth pointing out that it must be a new and unused chassis / shell to keep it all 100% legal
bi22le
posted on 19/5/14 at 08:04 PM |
I would take one of two actions if I was in your shoes.
1)Break the car for parts and makes as much money back as you can. Buy another car.
2) Buy the parts needed to rebuild new and build the parts back onto the new chassiss. I would stamp the same chassiss number and consider it an old
place replaced!
Depends on how ar$ed you can be.
Please read my ring story:
big_wasa
posted on 19/5/14 at 08:13 PM |
I would rebuild it with new parts. All legal and you will have a new car to the spec you want.
rick1962uk
posted on 19/5/14 at 09:54 PM |
dont scrap it i for one would pay for the chassis and v5 to rebuild with my parts
loggyboy
posted on 19/5/14 at 10:07 PM |
Its definately worth looking at the new chassis option, will likely work out lots cheaper than a new car or building up a used car to your spec. You
could with out much fear of reprecutions, just replace and not tell a soul.
If you want to do it officially then the body work is irrelevant, its not classed as a shell in the case of these cars. Providing you keep the majoity
(or some) of the original parts and use a brand new chassis you can just use the rebuilt vehicles route
https://www.gov.uk/vehicle-registration/rebuilt-vehicles
If you are set on scraping, see the last paragraph of this page. https://www.gov.uk/scrapped-and-written-off-vehicles/using-a-vehicle-for-parts
Mistral Motorsport
dhutch
posted on 20/5/14 at 07:58 AM |
new chassis.
I have to admit, thinking about where we want to go, thats what I would do to.
As far as i know you can re-shell a tintip, again, if you get a new and unused shell from the manufacturer and move the VIN number over. You can also,
again as far as i know, 're-shell' a car using a used shell and then use the details of the replacement shell. Aka you actually moving the
good bits onto the new car, not the good shell onto the old.
Daniel
alfas
posted on 6/6/14 at 09:18 AM |
isnt it possible...like with caterham/lotus...when the old chassis is bent, corroded etc...to sent it backto the manufacturer (arch motors for cat and
lotus).....they fabricate an identical new replacement chassis..remove the welded plate with chassisnumber from the old chassis, weld it to the new
chassis...job done.
this avoids that the "old" chassis is used for creating a clone....
Charlie_Zetec
posted on 6/6/14 at 10:24 AM |
As has been stated above, I'd purchase a new chassis and panels etc. and retain the original cars' ID. Just ask any Land Rover Defender
owner (myself included) who's put a new galvanised chassis on their vehicle. Some of the parts remain the same, but a lot of parts get
changed/upgraded in the process. Totally legal and legit. The chassis comes without a VIN number stamped on it, so down to the new owner to stamp it
themselves. But essentially you're replacing "like for like" just with newer parts.
alfas
posted on 6/6/14 at 10:29 AM |
yeah..now i remmeber the same procedure with a Lotus eclat i owned.....the original chassis was replaced by a new galvanized one..lotus
replacement....which came without number.....so the original number was stamped into the new chassis, the car was assembled again and drove around
with the original ID...
JMW
posted on 6/6/14 at 11:39 AM |
Thanks for all the previous posts. It looks like if I want to keep the car intact then a new chassis and panels is not a problem. The detail of this
means I will have to move from a SE narrow to a SEW as I don't think I can get all new SE narrow chassis and panel components. That would
actually suit me as I had to alter my SE narrow to move the pedals so I could drive it, as the SEW is also a bit longer I think. Note I am talking
about a live axle here.
As I said in my initial post though I don't think laying out for the above (and a cage as well), make it an economic repair to me, so I was
actually enquiring about how to "scrap" what I have but keep the bits of value, while complying with current legislation.
Thanks to the respondents on this thread I now know what to do to follow either path. I just have to choose!
