neilp1
posted on 20/5/14 at 08:13 AM |
Hazard tell tales
I have a digidash 2 which has a tell tale for indicators/hazards, but it only works with the ignition on. With hazards on with ignition off I have no
tell tales. Will this fail the IVA??
Smoking Frog
posted on 20/5/14 at 09:13 AM |
Yes, I believe so.
loggyboy
posted on 20/5/14 at 11:07 AM |
Can you see your indcators from the drivers seat?
If so you can apply note 1 of section 23:
Note 1: A tell tale is not required if the front indicators are directly clearly visible to the driver.
Mistral Motorsport
tims31
posted on 20/5/14 at 11:09 AM |
Do that hazards work and does the switch light when they are on, if so I'm not sure you need the tell tales on but thats not to say it
won't fail IVA.
I assume the digidash is wired to come on with the ignition switched on, is there no separate power wire for the indicators
Build: http://www.martinsfurybuild.co.uk/
neilp1
posted on 20/5/14 at 12:06 PM |
I can see the side repeaters from the drivers seat but not the front.
The switch lights up when the side/dipped lights are switch on.
rdodger
posted on 20/5/14 at 04:39 PM |
I have a digidash and passed IVA by making my hazard switch (Savage) flash with the hazards. My Savage switches light half bright with the lights and
full when in use.
